02.10.2024, 13:08
Check LM Error log. Are you using encrypted or plain connection?
MQTT Client app
02.10.2024, 13:08
02.10.2024, 13:11
02.10.2024, 13:37
Thanks, the problem is that your server does not support MQTT V5. It is required by the app to filter out unneeded messages. We can add a config option to allow older protocol versions to be used at your own risk
11.10.2024, 10:52
New app version has been published, see the first post.
New features:
(11.10.2024, 10:52)admin Wrote: [*]Added 1-bit Boolean to on/off string conversion[*] Thank you for keeping improving the application and also adding sorting to the table that makes it easier to manage mappings. I have few questions: 1) why you decided to make conversion incompatible with json path? Conversion allowed to simplify /SET topics for relays, but STATUS topics still need to take variable from json path and convert from on/off to boolean using script. I'm not sure why they can't work together. 2) why conversion values are case sensitive? AFAIK /SET commands for zigbee devices are case insensitive, and for STATUS values some send upper case, some send lower case. Of course one can first capture what end-device is sending and put exact value, but i don't see any breaking cases when upper/lower case actually matters. also little fix needed: for "In" mappings, it needs to be called "String to boolean conversion", as we're getting string from MQTT and need to write boolean value
14.10.2024, 11:08
Hi all,
How do i install the app? From system menu it requires signature file.
14.10.2024, 11:09
Apps are installed via app store Use install by file.
14.10.2024, 11:37
Forgot the three lines :-)
4 hours ago
App has been marked as stable and published in LM app store.
The latest version allows using JSON path together with boolean <-> string conversion. The conversion is no longer case sensitive for values coming from MQTT. |
