Threads: 28
Hi, how many group addresses per area? Are you going to pass all to LM or only some? What else is LM going to do apart of GUI?
Threads: 28
I would use one per area and this would dance nicely. You could try with one but it would depend on the other load you mentioned.If the traffic will be high this also might affect it. They should be placed on the IP side and set KNX mode to IP routing.
Threads: 2
Hi Thanks, Now I am using 1 LM5 for each area, Could you please guide me how will I make the Visualization of the complete project i.e all three area into one. Can I choose any one LM5 (out of three) for Complete Visualization or I have to make Visualization separately for each area in their respective LM5. If there is the possibility with latter one option then how to combine all three Visualization into one.
TIA
Threads: 28
The most common way is to make local visu on each LM and then select one where you will create links between so it looks like one. You can use frame or just a link.
Threads: 28
This has been identified and it is new browser security feature. Next firmware will have additional option to allow this anyway.
