Smartthings status update
Good morning and happy new year st all.
I'm working with Smartthings API, in command mode I reached good results. My problem it is the status update and I'm asking at the community if some other is working on this.... I 've thought to use the 'https://api.smartthings.com/v1/devices/<deviceId>/components/<componentID>/status' and create a resident script for x seconds to update the values reading the response Json.
I'm asking, is there a more pretty solution?
Best regards Cristian
Looks like polling is the only way to get the status info.
(02.01.2025, 11:35)admin Wrote: Looks like polling is the only way to get the status info.
How many time in a minute, by your experience, do you suggest? I don't want overload the communication with the cloud.
BR Cristian
This is a question for Smartthings support Smile
Check if API has any rate limits and adjust your scripts accordingly.
(02.01.2025, 14:30)admin Wrote: This is a question for Smartthings support Smile
Ok I will check again.
BR Cristian
