Threads: 86
Hi, I am working on integration with Milight.
I have to send UPD commands to manage the system.
Could you give me some details or example about the way to send UDP commands?
Threads: 41
Threads: 86
Thank you Admin,
just a quick information. As you can see in the link ( http://www.limitlessled.com/dev/) I have to send a datagram made of like below
UDP.SEND hex bytes: 20 00 00 00 16 02 62 3A D5 ED A3 01 AE 08 2D 46 61 41 A7 F6 DC AF (D3 E6) 00 00 1E <-- Send this to the ip address of the wifi bridge v6
In your opinion the following command can work? Because unfortunately it does not work:
local udp = socket.udp()
udp ![Confused Confused](https://forum.logicmachine.net/images/smilies/confused.png) ettimeout(200)
udp ![Confused Confused](https://forum.logicmachine.net/images/smilies/confused.png) endto('31x00x00x08x04x02x00x00x00','192.168.1.32','5987')
data = udp:receive()
log(data)
if I use udp ![Confused Confused](https://forum.logicmachine.net/images/smilies/confused.png) end it does not accepted.
Any suggestion?
Threads: 161
12.12.2016, 13:22
(This post was last modified: 12.12.2016, 13:35 by buuuudzik.)
You should type command in such form:
Code: cmd = string.char(0x31,0x00,0x00,0x08,0x04,0x02,0x00,0x00,0x00
You can use this function for sending with feedback:
Code: function send(cmd)
-- edit ip address and port
ip = '192.168.1.32'
port = 5987
local sock = require('socket').udp()
if sock then
sock:sendto(cmd, ip, port)
data = sock:receive()
sock:close()
return data
Threads: 6
12.12.2016, 14:04
(This post was last modified: 12.12.2016, 14:05 by Erwin van der Zwart.)
I would add a timeout on the receive socket as now it can hang forever..
Threads: 86
Erwing, you would add timeout setting after data = sock:receive ()?
Threads: 41
It must be before receive
Threads: 86
ok. I tried this:
function cmd (mioff)
ip = '192.168.1.32'
port = 5987
if sock then
sock ![Confused Confused](https://forum.logicmachine.net/images/smilies/confused.png) endto(cmd, ip, port)
sock ![Confused Confused](https://forum.logicmachine.net/images/smilies/confused.png) ettimeout(200)
sock:close()
return data
log(data)
as event function I used this following:
require("user.milight")
mioff = string.char(0x31,0x00,0x00,0x00,0x03,0x04,0x00,0x00,0x00,0x01)
cmd (mioff)
But I received the error below:
User Library "Milight", Line 8: bad argument #1 to 'sendto' (string expected, got function).
Threads: 41
First argument of sendto must be mioff not cmd
Threads: 86
I am tired...too late to coding.
Threads: 86
Code: function cmd (mioff)
ip = '192.168.1.255'
port = 48899
if sock then
sock:sendto(mioff, ip, port)
sock:settimeout(200)
sock:close()
return data
Hi there, I am going on to embadded Milight on HL unfortunately without success. User library above is not changed but HL error log tells me that on line 3:loop or previous error loading 'user.milight'.
Furthermore I tried to snif using wireshark and it seems that there is not any telegram sent by UDP to ny device. Event based script is the one shown below:
Code: require("user.milight")
mioff = string.char(0x80,0x00,0x00,0x00,0x11,0x00,0x31,0x00,0x00,0x08,0x04,0x02,0x00,0x00,0x00)
cmd (mioff)
Any suggestion?
Threads: 6
Can you try to put the function 'cmd' direct in your script (on top) without the require of a user lib?
Make sure there is no function called 'cmd' in your common functions to avoid a duplicate function.
Threads: 86
Code: mioff = string.char(0x80,0x00,0x00,0x00,0x11,0x00,0x31,0x00,0x00,0x08,0x04,0x02,0x00,0x00,0x00)
port = 48899
if sock then
sock:sendto(mioff,ip,port)
sock:close()
return data
Hi Erwin,
directly on event based I wrote this code but with Wireshark I cannot see any telegram leaving from HL to address 192.168.1.255.
What is wrong in your opinion?
Threads: 41
You must add sock:setoption('broadcast', true) before sendto
Threads: 86
Thank you admin. It is working.
Now I can work on the telegrams. I'll keep you informed.
Regards.
Threads: 86
I am sending the 0x4c,0x69,0x6e,0x6b,0x5f,0x57,0x69,0x2d,0x46,0x69. It is part of the same char which I read with Wireshark when I command light using android app of Milight.
I do not understand the reason why when I send commands by Milight Android app telegram lenght is 52 instead sending telegram (just string above) lenght is 60.
The problem is thay I should send further data but telegram will be longer. What is your thoughs?
Threads: 86
Hi, I found on web this script to integrate Milight led. There are udp commends. Could you let me know if it is suitable for HL or some instruction should be modified?
local IP = 192.168.1.2
local Port = 5987
local ZoneID = string.char(0x01)
--List of Commands
local Init = string.char (0x20,0x00,0x00,0x00,0x16,0x02,0x62,0x3A,0xD5,0xED,0xA3,0x01,0xAE,0x08,0x2D,0x46,0x61,0x41,0xA7,0xF6,0xDC,0xAF,0xFE,0xF7,0x00,0x00,0x1E)
local Preample = string.char (0x80,0x00,0x00,0x00,0x11)
local Filler = string.char (0x00)
local On = string.char (0x31,0x00,0x00,0x08,0x04,0x01,0x00,0x00,0x00)
local Off = string.char(0x31,0x00,0x00,0x08,0x04,0x02,0x00,0x00,0x00)
--Generate random Sequential Byte just helps with keeping commands in the correct order, and it helps to ignore duplicate packets already received.
math.randomseed(os.time())
math.random(); math.random(); math.random()
local RandomNumber = math.random(255)
local SequentialByte = string.char(RandomNumber)
--Action
local Command = On
--Send Init and wait for response
local Response={}
socket = Net.FUdpSocket()
socket:setBroadcast(true)
bytes, ErrorCode = socket:write (Init, IP, Port)
if ErrorCode == 0 then
local ResponseLength = 1
while (ErrorCode==0 and ResponseLength>0 and ResponseLength~=22) do
Response, ErrorCode = socket:read()
ResponseLength = string.len(Response)
--Extract data from UDP response
local MAC = Response:sub(0x09,0x0E)
local WifiBridgeSessionID1 = Response:sub(0x14,0x14)
local WifiBridgeSessionID2 = Response:sub(0x15,0x15)
local Payload = Preample..WifiBridgeSessionID1..WifiBridgeSessionID2..Filler..SequentialByte..Filler..Command..ZoneID..Filler
local ChksumString = Payload:sub(0x0B)
--Calculate Checksum
local i = 1
local Chksum = 0
while i <= ChksumString:len() do
Number = ChksumString:sub(i,i)
Chksum = Chksum + tonumber(Number:tohex(),16)
i = i + 1
--Calculate remainder Chksum%256 same as &0xFF
Chksum = (Chksum - math.floor(Chksum/256)*256)
local Chksumchar = string.char(Chksum)
Payload = Payload..Chksumchar
Response={}
bytes, ErrorCode = socket:write (Payload, IP, Port)
while (ErrorCode==0 and ResponseLength>0 and ResponseLength~=8) do
socket = nil
local Result = ""
local ResultByte = Response:sub(0x08,0x08)
local ResponseSequentialByte = Response:sub(0x07,0x07)
if (ResponseSequentialByte==SequentialByte and ResultByte==Filler) then
Result = "Successfull"
Result = "Failed"
Threads: 6
Could work, i looked short but already noticed that the socket declaration must be changed to HL socket connection.
Will check tommorow evening..
Threads: 86
Thank you Erwin. I await for your response before test. It is a good opportunity to integrate another system of market.
Regards.
Threads: 6
15.03.2017, 21:45
(This post was last modified: 15.03.2017, 21:55 by Erwin van der Zwart.)
Just checked your script but it's incomplete, i changed the socket and added comments on socket changes and to your missing functions..
Code: require('socket') -- added socket lib
local IP = '192.168.1.2' -- added set ip into ''
local Port = 5987
--List of Commands
--Action
local Command = On
local Response={}
local client = socket.udp() -- added socket client
clientConfusedetBroadcast(true) -- missing function don't know what it should do
bytes, ErrorCode = client:write (Init, IP, Port) -- changed socket request
Response, ErrorCode = client:read() -- changed socket request
local MAC = ResponseConfusedub(0x09,0x0E) -- missing function don't know what it should do
local WifiBridgeSessionID1 = ResponseConfusedub(0x14,0x14) -- missing function don't know what it should do
local WifiBridgeSessionID2 = ResponseConfusedub(0x15,0x15) -- missing function don't know what it should do
local Payload = Preample..WifiBridgeSessionID1..WifiBridgeSessionID2..Filler..SequentialByte..Filler..Command..ZoneID..Filler --missing ID1 & ID2 result due to missing functions
local ChksumString = PayloadConfusedub(0x0B) -- missing function don't know what it should do
local i = 1
local Chksum = 0
Number = ChksumStringConfusedub(i,i)
Chksum = Chksum + tonumber(Number:tohex(),16) -- i think this must be lmcore.intohex()
i = i + 1
Response={}
bytes, ErrorCode = client:write (Payload, IP, Port) -- changed socket request
client = nil
local Result = ""
local ResultByte = ResponseConfusedub(0x08,0x08) -- missing function don't know what it should do
local ResponseSequentialByte = ResponseConfusedub(0x07,0x07) -- missing function don't know what it should do
if (ResponseSequentialByte==SequentialByte and ResultByte==Filler) then -- missing Byte due to missing function
Result = "Failed"
You probably will get a reply as 'Response' but the extraction of the reply data would need to be rebuild without the additional functions ..
