Threads: 60
Is it possible to apply usermode view "Center horizontally, auto-size width" to specific plans (not to all project)?
Threads: 43
Not possible, this setting is global for all plans.
Threads: 60
(19.09.2024, 11:00) admin Wrote: Not possible, this setting is global for all plans.
And is it not possible to override using css or js in any way?
Threads: 43
Explain in more detail what do you want to achieve.
Threads: 60
(19.09.2024, 11:05) admin Wrote: Explain in more detail what do you want to achieve.
I want to use some plans as mobile visualitzation (like a menu view) and need to scroll up/down and I want to use other plans as desktop visualitzation (and need to fit them to the screen)
Threads: 60
Is there any way to do it?
Threads: 43
Only one view mode is supported for all users.
Threads: 60
03.03.2025, 07:40
(This post was last modified: 04.03.2025, 06:43 by jmir .)
(03.03.2025, 07:38) admin Wrote: Only one view mode is supported for all users.
And is it not possible to override this mode for specific plans? (not users)
Threads: 60
(03.03.2025, 07:40) jmir Wrote: (03.03.2025, 07:38) admin Wrote: Only one view mode is supported for all users.
No way to override for specific plans?
Threads: 43
Try this CSS, adjust plan IDs as needed. Some features like backgrounds won't work correctly.
1 2 3 4 5 6 7 8 9 10 11 12
layers {
overflow-y :
auto ;
plan-2 ,
plan-3 {
transform :
none !
important ;
margin :
0 auto !
important ;
position :
relative !
important ;
top :
auto !
important ;
left :
auto !
important ;
Threads: 2
05.03.2025, 10:12
(This post was last modified: 05.03.2025, 10:13 by didac .)
Hello.
I have tried the code and it doesn't work. Is it possible to apply the Usermode View "Center plans, enable auto-sizing" on a specific plan using css or js?
Threads: 43
No, it's not possible.
Did you adjust the rules with relevant plan IDs?
Threads: 2
(05.03.2025, 10:15) admin Wrote: No, it's not possible.
Yes, I have set the rule according to the id plan. It doesn't work
Threads: 43
You need to set view mode to "Center plans, enable auto-sizing". Plans added to the CSS rule will be shown as is using their original size without scaling. If plan height is larger than the screen height then a scrollbar will appear.
Threads: 43
Try this:
CSS:
layers {
overflow-y :
auto ;
layer-centered-h {
margin-top :
0 !
important ;
JS (change scrollIds array as needed):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
var origDoShowPlan =
window.doShowPlan
if (
origDoShowPlan ) {
var scrollIds = [
2 ,
3 ,
4 ]
function () {
scrollIds.forEach (
function (
id ) {
'#plan-' +
id ).
addClass (
'layer-centered-h' )
doShowPlan =
function (
plan ) {
visAutoWidth =
scrollIds.indexOf (
currentPlanId ) >=
origDoShowPlan (
plan )
Threads: 2
Changing the set view mode and using the above code works, but only with 1920x1080 screens. With smaller screens, I can't see the full width. Also, with this modification, I can't scroll if I open a widget. Now I'll try this new example.
Threads: 60
(05.03.2025, 13:02) admin Wrote: Try this:
CSS:
layers {
overflow-y :
auto ;
layer-centered-h {
margin-top :
0 !
important ;
window.doShowPlan
if (
origDoShowPlan ) {
var scrollIds = [
2 ,
3 ,
4 ]
function () {
scrollIds.forEach (
function (
id ) {
'#plan-' +
id ).
addClass (
doShowPlan =
function (
plan ) {
visAutoWidth =
scrollIds.indexOf (
currentPlanId ) >=
origDoShowPlan (
plan )
Hi, I've done some tests and it works if don't open any widget... When I do it (inside a scrollable plan) then scrollbar appears on non-scrollable plans...
Threads: 43
Remove from CSS:
layers {
overflow-y :
auto ;
Modify JS:
doShowPlan =
function (
plan ) {
visAutoWidth =
scrolIds.indexOf (
currentPlanId ) >=
'.layers' ).
css (
'overflow-y' ,
visAutoWidth ?
'auto' :
'hidden' )
origDoShowPlan (
plan )
Threads: 60
(06.03.2025, 14:54) admin Wrote: Remove from CSS:
layers {
overflow-y :
auto ;
Modify JS:
doShowPlan =
function (
plan ) {
visAutoWidth =
scrolIds.indexOf (
currentPlanId ) >=
'.layers' ).
css (
'overflow-y' ,
visAutoWidth ?
'auto' :
'hidden' )
origDoShowPlan (
plan )
Now I does not switch between plans....
Threads: 43
You need to replace only the doShowPlan function not the whole JS code. Complete JS should look like this:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
window.doShowPlan
if (
origDoShowPlan ) {
var scrolIds = [
2 ,
3 ,
4 ]
function () {
scrolIds.forEach (
function (
id ) {
'#plan-' +
id ).
addClass (
doShowPlan =
function (
plan ) {
visAutoWidth =
scrolIds.indexOf (
currentPlanId ) >=
'.layers' ).
css (
'overflow-y' ,
visAutoWidth ?
'auto' :
'hidden' );
origDoShowPlan (
plan )
