Zigbee gateway integration
Did you try opening network and setting device in to pairing mode?
Can we add this profile? It's for Wireless Emergency Lightning, or will the GreenPower clusters be an issue like with the Powertags?
1234567891011121314151617181920212223242526272829
Manufacturer: Schneider Electric Model: OVA47211 Firmware version: 001.001.001 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - OnOff (6) - HaDiagnostic (2821) - 65301 - 65316 Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - onoff: false - prevlevel: 254
Profile is not needed for On/Off control.
There are two custom clusters which cannot be implemented without documentation.
Thanks, I will ask our team to see if we can implement it somehow, tbc..
I have installed the VIMAR ‘wheelthermostat’ thermostat on some installations and recently VIMAR updated its firmware to version 1.06, it is no longer recognised the Zigbee module.
I've put the two profiles below and there's nothing that changes except the version.
Is there anything we can do?
The old Firmware
Model: WheelThermostat_v1.0
Firmware version: 1.0.0_z
Device type: Router
Power source: Mains
Endpoint 10
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- HvacThermostat (513)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- coolingstatus: false
- heatingstatus: true
- localtemperature: 18.60
- occupiedcoolingsetpoint: 40.00
- occupiedheatingsetpoint: 18.00
- systemmode: 4
The new one
Fabricant: Vimar
Modèle : WheelThermostat_v1.0
Version du micrologiciel : 1.0.6_z
Type d'appareil : routeur
Source d'alimentation : secteur
Recevoir en mode inactif : Oui
Point final 10
 Profil : 260
 Groupes d'entrée
 - Basique (0)
 - Identifier (3)
 - Identifier (3)
 Groupes de sortie
 - Thermostat CVC (513)
Point final 242
 Profil : 41440
 Groupes de sortie
 - Énergie verte (33)
Attributs signalés
 - état de refroidissement : faux
 - statut de chauffage : faux
 - température locale : 21,70
 - point de consigne de refroidissement occupé : 40,00
 - point de consigne de chauffage occupé : 20,00
 - mode système : 0
Contact the thermostat manufacturer. They've moved HvacThermostat cluster from Input clusters to Output clusters so commands cannot be sent to it anymore.
Most likely they wanted to put HvacThermostat cluster into both Input and Output but instead they have Identify Input cluster listed twice.
(10.03.2025, 14:11)admin Wrote: Contact the thermostat manufacturer. They've moved HvacThermostat cluster from Input clusters to Output clusters so commands cannot be sent to it anymore.
and it's not possible to do something manually via script?
I've been looking for a long time for a wired Zigbee thermostat that works and now I'm back to zero.
The Schneider electric S520619 thermostat is still not compatible.
Model: S520619
Firmware version: 001.000.053
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- HvacUserInterfaceCfg (516)
- ManuSpecificWiserEvent (65027)
- ManuSpecificCycleTime (65302)
- ManuSpecificHeatingCooling (65315)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
- MsTemperatureMeasurement (1026)
- MsOccupancySensing (1030)
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 4
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 5
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- SeMetering (1794)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- occupancy: true
- temperature: 19.22
Some other Schneider Electric thermostats are already supported. S520619 looks quite similar so it will be added to the app. I'll send you a test version when it's ready.
Is it possible to read the Zigbee version of a device from applibs.zigbee? If yes how, i need to determine if Zigbee 2 or 3 is used before sending the HW to a 3th party..
You can try reading the Stack version attribute. But it's optional so you might not get a reply from the device.
zb = require('applibs.zigbee') -- Basic / StackVersion res, err = zb.cmdsync('getrawattribute', '0123456789abcdef', 0, 2) log(res, err)
Thnks but to bad.. Any other ideas?
Test 14.03.2025 12:15:26 * arg: 1   * nil * arg: 2   * nil
I don't see any other options in the standard.
When i do this:
zb = require('applibs.zigbee.zigbee') addr = '04cd15fffe7ccf75' cluster = 0x0000 -- Basic attrs = { 'ZCLVersion' } res, err = zb.cmdsync('getnamedattributes', addr, cluster, attrs) log(res, err)
I get back this:
* arg: 1   * table:    ["ZCLVersion"]     * number: 3
Isn't that the Zigbee version?
It's ZigBee Cluster Library version. Newer devices will report a larger number, for example 8.
is possible to share latest zigbee plugin like a file here?
Alexander
Our partners use different hardware version for zigbee and due to this our app is not compatible with other brands. We will not share this app to create confusion and more support for us.
