Aseko Asin Aqua Home
hello,
I have this product to manage my pool https://www.asekopool.com/fr/asin-aqua-home-fr/
and I have retrieved this file but I don't know where to start to create a json to be able to integrate it on my LM.
.pdf   RS485 communication protocol - AA Home,Salt,Oxy.pdf (Size: 39.33 KB / Downloads: 21)
Json profiles are for modbus integration where this seems like some custom RS485 protocol. Here is serial library:
https://kb.logicmachine.net/libraries/serial/
(02.07.2025, 11:05)Daniel Wrote: Json profiles are for modbus integration where this seems like some custom RS485 protocol. Here is serial library:
do you think it will work like this ? -- Charger la bibliothèque série require('serial') -- Ouvrir le port série RS-485 if not port then     port = serial.open('/dev/RS485', {         baudrate = 57600,         parity = 'none',         databits = 8,         stopbits = 1,         duplex = 'half'     })     port:flush() end -- Fonction pour convertir les octets en valeur numérique local function to_decimal(high, low, factor)     return (high * 256 + low) / factor end -- Port prêt pour la lecture if port then     -- Lire un paquet de données     local data, err = port:read(27, 2)  -- Lire 27 octets     if data then         local bytes = {string.byte(data, 1, 27)}         -- Extraction des données         local ph_value = to_decimal(bytes[3], bytes[4], 100)         local ph_required = bytes[17] / 10         local cl_rx_value = to_decimal(bytes[5], bytes[6], 100)         local cl_rx_required = bytes[18] / 10         local temperature = to_decimal(bytes[9], bytes[10], 10)         local error_1 = bytes[11]         local error_2 = bytes[24]         local unit_type = bytes[2]         -- Écriture des valeurs sur le bus KNX         grp.write('1/1/1', ph_value)         grp.write('1/1/2', ph_required)         grp.write('1/1/3', cl_rx_value)         grp.write('1/1/4', cl_rx_required)         grp.write('1/1/5', temperature)         grp.write('1/1/6', error_1)         grp.write('1/1/7', error_2)         grp.write('1/1/8', unit_type)         -- Journaux pour chaque information         print(string.format("pH: %.2f, pH requis: %.1f", ph_value, ph_required))         print(string.format("CL/RX: %.2f, CL/RX requis: %.1f", cl_rx_value, cl_rx_required))         print(string.format("Température: %.1f °C", temperature))         print(string.format("Erreur 1: %d, Erreur 2: %d", error_1, error_2))         print(string.format("Type d'unité: %d", unit_type))     else         print("Erreur de lecture des données: " .. tostring(err))     end     -- Fermeture du port pour éviter de laisser la connexion ouverte     port:flush()     port:close() end
Do you use LM?
Don't close the port after the first read operation. You should also check the starting byte value and whether calculated CRC matches the last byte. Otherwise you might get incorrect data occasionally.
(03.07.2025, 07:13)Daniel Wrote: Do you use LM?
YES
