Modbus profile - read_count
How to use the read_counter into a MODBUS profile file?
I have a MODBUS water-meter where I can only read the 4 register in one shot.
Register definition is like this:
Yeap, I's crazy. Not sure if I can do it by using profile, or I have to use a LUA script...
Ben
You can read multiple registers via a profile but this decimal data type is not supported.
First, use read test to find the correct register address. It can be 40001, 40000 or 0.
Use this script for reading. Keep the relevant RTU port enabled in the Modbus tab. Change device id (2) and address (40001) as needed.
mbproxy = require('mbproxy') mb = mbproxy.new() mb:setslave(2) r1, r2, r3, r4 = mb:readregisters(40001, 4) -- read ok if r1 then   consumption = r1 + r2 / 10000   flowrate = r3 + r4 / 10000   log(consumption, flowrate) else   log('read failed', r2) end
