Visu bugs
#21
When accessing the new Visu app from my smart device, i see the menu on the left,
instead of just the screen I designed. Is this normal?
Go to General settings and see the: Plan view menu display mode:
Is it possible to open visu on clients tablet in full screen mode?
As i see it now, there is a white strip in the area outside the area i designed.
Use LM Home
(28.10.2025, 16:16)Daniel Wrote: Use LM Home
This is the app I use, but there are white stripes above and below the screen. See picture above.
Similarly on another device, the stripes appear on the left and right.
Go to Global appearance and play with Page background setting.
Why if i use a Widget configuration (Frame) with Frame source URL:
/apps/data/mqtt-broker/ or /apps/data/mqtt-client/
in LM Home it works in local network but remotely i have error 404 not found?
Frame doesn't pass data to cloud, this will never work. You would need to have broker in cloud like trends/schedulers.
For remote access use Zerotier.
(29.10.2025, 10:54)Daniel Wrote: Frame doesn't pass data to cloud, this will never work.  You would need to have broker in cloud like trends/schedulers.
it means all the webpages inside the app folder could not be used  remotely in LM Home?
User access control ->   /apps/data/tempaccess/
Temporary access ->     /apps/data/useraccess/
Alert manager -> /apps/data/alerts/
Correct.
I've encountered a problem with the new v20251028 update; it's not working on an 8" IPS 1280 x 800 screen running Android 12.0. I had it running with version 20250813, but the new version doesn't fully load the new interface. I reverted to version 20250813, and it's working perfectly again.
Uploaded new version, see if this helps. Seems your browser was not updated in last years.
It's possible, although the screen is new, the built-in browser might be outdated. I installed Fully Kiosk Browser, but it didn't work either.
With this new version, it's working correctly again.
(29.10.2025, 08:04)Daniel Wrote: Go to Global appearance and play with Page background setting.
Still the same effect.
I thing it has to do with the way the application runs on the client device.
@Chandrias, plan view is scaled automatically to fit inside of the whole screen while keeping the aspect ratio. Because different devices have different screen aspect ratios you get blank space on either vertical or horizontal edges.
As Daniel said, check Global appearance settings > General > Page background color. You can test it in your PC browser by resizing the window. Blank space will display the selected background color.
I have two bugs, it seems. Or maybe one bug and one feature, but if it's a feature I don't like it Wink
1: If you create a custom widget with a "value select" widget, the list of values is cut off at the bottom of the widget size. I would expect it to get on top of widgets below, like it does when used not in a custom widget... If this is a feature, it's weird Smile
2: When using the Light widget, control mode scale, and "Enable widget compact mode in Plan view" AND the "Show on/off toggle" enabled, the on/off status is not working in Plan view. It works in Tile. And if I disable the "Enable widget compact mode in Plan View", it's ok in Plan as well...
And sorry for posting too much recently...
1. It is an edge case, why don't you use Select? We will see what can be done, not sure if can be fixed.
2. Thanks it is a bug.
And don't be sorry, the more we find the better Smile
(05.11.2025, 13:59)Daniel Wrote: 1. It is an edge case, why don't you use Select? We will see what can be done, not sure if can be fixed.
Not using select because I only want the icon showing... Value Select is absolutely perfect, but it's rather useless in a custom widget...
And to follow up the light widget - when you enable the step-buttons, shouldn't they be visible when "Enable widget compact mode in Plan view" is selected as well..?
Steps- no, this is by design.
Ok... But maybe I have another bug for you then - still the light widget. If "Enable widget compact mode in Plan View" enabled, display mode is "Value" and "Show on/off toggle" is enabled - then "Additional values / icons" won't work. I want the value 0 to be the norwegian word "Av" instead of the default "Off". This works as expected when "Show on/off toggle" is disabled, but not when it's enabled...
Attached. When I turn off the GA with the wall switch, I can see it says "Av" for maybe quarter of a second, before it turns to "Off".
And again, as soon as I disable "Show on/off toggle", it's working as expected.
(Did you just delete your reply to me?)
