widget problem
I'm having problems with widgets. On one LogicMachine, once I open a widget, if I click elsewhere, it closes, but on another, it doesn't.
Same firmware version and same widget configuration. What's the problem?
Thank you very much.
Which visualization do you use?
(05.11.2025, 08:21)Daniel Wrote: Which visualization do you use?
OLD VISU IN THE SAME LOGICMACHINE
Provide some more info for us to be able to reproduce the behaviour, or share the backup and tell which widgets.
(05.11.2025, 09:29)Daniel Wrote: Provide some more info for us to be able to reproduce the behaviour, or share the backup and tell which widgets.
This is the backup , user admin pwd Admin2025
the widget isall the present widget , not close when open and click in other part of page.
It is the image behind blocking it, add this to custom css
.item-image { pointer-events: none; }
