28.11.2025, 08:26
Can you post full device information window output for both devices?
Zigbee gateway integration
28.11.2025, 08:26
28.11.2025, 08:32
(28.11.2025, 08:26)admin Wrote: Can you post full device information window output for both devices? Sure, here it is: Manufacturer: SONOFF Model: SNZB-02LD Firmware version: 1.1.0 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - MsTemperatureMeasurement (1026) - PollCtrl (32) - 64599 - 64529 Output clusters - Ota (25) Reported attributes - temperature: 17.20 Manufacturer: BOSCH Model: RBSH-SP-ZB-EU Firmware version: 2.5 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - SeMetering (1794) - HaElectricalMeasurement (2820) - HaDiagnostic (2821) Output clusters - Identify (3) - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - currentsummdelivered: 0 - haactivepower: 0 - hapowerdivisor: 1 - hapowermultiplier: 1 - onoff: false - prevlevel: 254 - sepowerdivisor: 100 - sepowermultiplier: 1
01.12.2025, 18:27
I have bought a Heiman WarningDevice-EF-3.0, which is in the supported list devices. But I only get "detection" and "low battery detected" which are not useful. Maybe is because I have a Wiser for Knx?, I have the last firmware update. Here is the info:
Manufacturer: HEIMAN Model: WarningDevice-EF-3.0 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - Groups (4) - SsIasZone (1280) - SsIasWd (1282) - HaDiagnostic (2821) Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - detection: false
02.12.2025, 09:39
SE is updating Zigbee app on its own, our list may not match what is supported by SE. Detection seems the only thing this device reports. What else would you want from this sensor?
02.12.2025, 17:54
Yesterday, 09:04
OK I thought it is a smoke detector, still you should contact SE.
Ctrl+F5 |
