28.11.2025, 08:26
Can you post full device information window output for both devices?
Zigbee gateway integration
28.11.2025, 08:26
28.11.2025, 08:32
(28.11.2025, 08:26)admin Wrote: Can you post full device information window output for both devices? Sure, here it is: Manufacturer: SONOFF Model: SNZB-02LD Firmware version: 1.1.0 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - MsTemperatureMeasurement (1026) - PollCtrl (32) - 64599 - 64529 Output clusters - Ota (25) Reported attributes - temperature: 17.20 Manufacturer: BOSCH Model: RBSH-SP-ZB-EU Firmware version: 2.5 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - SeMetering (1794) - HaElectricalMeasurement (2820) - HaDiagnostic (2821) Output clusters - Identify (3) - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - calclevel: 0 - currentsummdelivered: 0 - haactivepower: 0 - hapowerdivisor: 1 - hapowermultiplier: 1 - onoff: false - prevlevel: 254 - sepowerdivisor: 100 - sepowermultiplier: 1
01.12.2025, 18:27
I have bought a Heiman WarningDevice-EF-3.0, which is in the supported list devices. But I only get "detection" and "low battery detected" which are not useful. Maybe is because I have a Wiser for Knx?, I have the last firmware update. Here is the info:
Manufacturer: HEIMAN Model: WarningDevice-EF-3.0 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - Groups (4) - SsIasZone (1280) - SsIasWd (1282) - HaDiagnostic (2821) Output clusters - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - detection: false
02.12.2025, 09:39
SE is updating Zigbee app on its own, our list may not match what is supported by SE. Detection seems the only thing this device reports. What else would you want from this sensor?
02.12.2025, 17:54
03.12.2025, 09:04
OK I thought it is a smoke detector, still you should contact SE.
04.12.2025, 12:12
I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated.
Code: Manufacturer: IKEA of Sweden
Model: INSPELNING Smart plug
Firmware version: 2.4.45
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- SeMetering (1794)
- LightLink (4096)
- 64636
- 64645
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Input clusters
- GreenPower (33)
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- currentdivisor: 1000
- currentmultiplier: 1
- currentsummdelivered: 0.4
- hapowerdivisor: 10
- haactivepower: 192.4
- level: 254
- onoff: true
- prevlevel: 254
- rmscurrent: 0.9
- rmsvoltage: 230.4
- sepowerdivisor: 1000
- voltagedivisor: 10
- voltagemultiplier: 1(And it's a bit weird with dimming properties on a on/off socket - but that's not really a problem)
04.12.2025, 12:58
(04.12.2025, 12:12)stianj Wrote: I just bought an IKEA Inspelning smart plug with energy meter. It's not in the list of supported devices, I know. But it joins just fine, and under configure I have both "RMS Voltage", "RMS Current" and "Energy delivered". All good! Except that the values don't update unless I read device status manually. Then it's updated. Hi, Have you tried rejoining it to the zigbee network, that helped for me. Greetz, Tigi
04.12.2025, 13:01
Voltage/current/power reporting won't work without a profile. Some devices will report values automatically but most devices won't send reports unless the gateway subscribes to them.
04.12.2025, 13:15
Yeah, I suspected so. So... will you pretty please consider adding it in the next version..?
08.12.2025, 13:09
New app version has been published. Added support for Ikea INSPELNING Smart plug, BOSCH RBSH-SP-ZB-EU and SONOFF SNZB-02LD. Please reset your devices and pair them again.
08.12.2025, 17:02
Thank you very much! Works perfect
08.12.2025, 17:55
Hi Admin,
Thanks for the update! Greetz, tigi
hello,
I have smoke detector Aqara sd-s01e but when smoke detection i don't have the detection object knx change. any idea ? need to ask the detector by script ? AttributeIdentifier = 5, Type = "string", Value = "lumi.sensor_smoke.acn03" Xiaomi/Aqara (modèle acn03) ManufacturerCode = 4447 et le ClusterId = 64704 ou 0xFCC0 AttributeIdentifier = 247 (ou 0xF7 en hexadécimal, souvent utilisé par Xiaomi pour les données multi-attributs) Value = [62] 01 21 **3D 0B** 03 28 19 IAS Zone Status (Cluster 0x0500, Attribut 0x0002) IAS Zone (0x0500)
FRANCE SMARTHOME & SMARTBUILDING INTEGRATION SE ECO EXPERT
11.12.2025, 07:56
15.12.2025, 06:44
(11.12.2025, 07:56)admin Wrote: See this: https://forum.logicmachine.net/showthrea...2#pid40162 i saw it. But i was thinking with script a possibility to update it. I tried: if not zb then zb = require('applibs.zigbee.zigbee') local address = '54ef441000d98b22' -- Adresse IEEE de votre détecteur de fumée cluster = 0xFCC0 -- Cluster IAS Zone (Alarme de Sécurité) 1280 attrs = { 0x0002 }-- Get rmscurrent from HaElectricalMeasurement cluster local res, err = zb.cmdsync('getrawattribute', address, cluster, 295 ) -- 0x0002 est l'Attribut Zone Status -- Log the result or the error if err then log("Error retrieving val: " .. err) else log("Val: " .. tostring(res)) end end script.disable(_SCRIPTNAME) without luck So your point is that i should change them ? there will be no support in futur ?
15.12.2025, 07:42
You can't read most battery powered device this way. The device is sleeping most of the time and won't receive any messages.
This particular sensors is broken and won't be supported. You are using SE app version which is not developed by us. I doubt that they have any interest in supporting third party devices.
15.12.2025, 08:09
yes SE is blocking lots of cool stuf...
ok so i will change them ! Thanks
15.12.2025, 08:55
SE indeed blocks cool and useful stuff.
I have a Namron 4512784 thermostat that I don't think is fully supported by either LM or SE. the readout is: Code: Manufacturer: Namron AS
Model: 4512784
Firmware version: 1.12
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- HvacThermostat (513)
- HvacUserInterfaceCfg (516)
- MsRelativeHumidity (1029)
- SeMetering (1794)
- LightLink (4096)
- 57346
Output clusters
- Identify (3)
- Ota (25)
- MsOccupancySensing (1030)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- currentdivisor: 1
- currentsummdelivered: 21.4
- hapowerdivisor: 1
- humidity: 45.0
- haactivepower: 0
- localtemperature: 22.00
- occupiedheatingsetpoint: 21.50
- onoff: true
- picoolingdemand: 0
- piheatingdemand: 0
- prevlevel: 254
- rmscurrent: 0
- sepowermultiplier: 1However, if I read from the hybrid app for device status and control I see the following: Code: Device status
OnActive power: 0.0WRMS current: 0.00AEnergy delivered: 30.20kWhKeypad lockout: 1So there is information/objects there, I just cannot map it correctly in the hybrid app. Is it possible to extract setpoint and energy delivered via script somehow?
18.12.2025, 08:58
Check this: https://kb.logicmachine.net/libraries/zi...-attribute
For Voltage/Current/Power the formula is value * Multiplier / Divisor. In most cases multiplier and divisor are fixed values. |
