Tile View
Hi, Normally, in house visualizations, in the plan view we use a background with the floor plan and place the different room elements on top of each corresponding area. When switching to tile view, all the elements (thermostats, blinds, etc.) end up on a single screen. Is there an option to have each room appear in a different tile? Otherwise, in the mobile view there are too many elements on the same screen and it’s not intuitive at all (and to reach the ones at the bottom you have to scroll a lot…). What would be the best way to organize this?
You have two options:
1. Use category widget and move widgets from each room inside.
2. Create two separate visualizations. You can define one plan to be only for Plan view and another only for Tile view. This way you can make Tile view totally independent from Plan.
(Yesterday, 09:43)Daniel Wrote: You have two options:
Ok, but I still have two problems with this:
  1. I can use categories, but if I have 10 rooms, I would still need to scroll a lot.
  2. If I define the Tile view and the Plan view independently, then in the future, if I need to change anything, I would have to update it in both views.
Is there a solution?
