LM Home app (Andrоid/iOS starter)
You must use a domain name for HTTPS. IP can only be used for plain HTTP.
(19.01.2026, 13:27)admin Wrote: You must use a domain name for HTTPS. IP can only be used for plain HTTP.
Using domain name doesn't work neither...
Is there any way that you can test it using our URL?
Send your URL via PM but most likely we can't test it this way.
how can I get the apk? I have a lot of Phillips displays. Neither of them supports Goole play.
What is the Android version on this display?
(23.07.2026, 09:24)Daniel Wrote: What is the Android version on this display?
Android version 13
https://www.transfernow.net/dl/20260723rQhzp6Es
