Javascript on Trends Page
Is Custom javascript running on trends page?
I want to use a function to jump to visu start page after a time when no activity, but on trends page (and schedulers) it doesn't work...
Is there any way to do it?
Post your script.
(22.01.2026, 07:04)admin Wrote: Post your script.
I'm using this:
https://forum.logicmachine.net/showthrea...ght=logout
It won't work because certain variables (currentPlanId) and functions (showPlan) are not defined in trends.
Try this for trends and schedulers. Adjust timeout value and location as needed.
$(function() {   var body = $('body')   var timeout = 90 // seconds      if (body.hasClass('trends') || body.hasClass('schedulers')) {     var events = ['pointermove', 'keydown', 'click', 'scroll']     var ticks = 0        function reset() {       ticks = 0     }        events.forEach(function(event) {       document.addEventListener(event, reset, true)     })          setInterval(function() {       ticks++              if (ticks >= timeout) {         window.location = '/apps/'       }     }, 1000)   } })
(22.01.2026, 07:49)admin Wrote: It won't work because certain variables (currentPlanId) and functions (showPlan) are not defined in trends.
Hi, It works!
Is there a way to adapt this function so that it also works in the visualisation and redirects to a specific plan?
Replace window.location = '/apps/' with this, change 123 to the real plan ID:
if (window.showPlan) {   window.showPlan(123) } else {   window.location = '/apps/' }
It works, I've added body.hasClass('usermode') and an extra if to check if we're on initial plan
Perhaps something can be improved...
  $(function() {     var body = $('body')     var timeout = 10 // seconds     var ini_plan_id = 7 //numero de la pantalla inicial     if (body.hasClass('trends') || body.hasClass('schedulers')  || body.hasClass('usermode') ){       var events = ['pointermove', 'keydown', 'click', 'scroll']       var ticks = 0       function reset() {         ticks = 0       }       events.forEach((event) => document.addEventListener(event, reset, true))       setInterval(() => {         ticks++         if (ticks >= timeout) {           if (window.showPlan) {             if (window.currentPlanId !== ini_plan_id) {               window.showPlan(ini_plan_id)             }                      }           else {             window.location = '/scada-vis/'           }         }       }, 1000)     }   })
