blind control on Visu
Hi, what is the better way to control a blind from the new Visu ?
When I use this control
I have a problem with the slats ( I think the bit stop doesn't work properly. I can't open and close slats by singol tap on the button.....the stop is always in the same direction).
Alberto
KNX Advanced Partner + Tutor
This was designed for window/blind actuator. What is the difference for the shutters?
With the shutters the bit stop always works (0 or 1 value).
With the blinds the bit stop has a sense ( 0 --> open slats by one step , 1 --> close slats by one step ).
for example there are 10 steps to open/close the slats completely
The best think is with short and long command (is it possible ?...or I have to use javascript).
Otherwise...How can I change the value of the stop ?
Why don't you use byte control instead?
because it has one more tap for use ....and vertical slide is not good in plant (too big) because I have 4 motors for every windows
one think.....I'm using the step control (it is good with long and short !!) but I have a problem.
I have the central stop button changes state by the Movement status
I think the change active state could be at the up/down button and not on the stop button (or their could change by the position status).
am I doing something wrong?
Alberto
It shows what is the active state, if blinds move then the left/right is highlighted if stop then the middle.
ok, but I don't see the final status of the blind....closed or opened ?
It is not about blind status, it is about, is it moving or did it stop. There is position status object which can display position in %, use icon and value.
is it possible insert an option that send the stop when I release the button ?
Do you mean when short/long press option is enabled?
Is there no widget on Visu that displays in graphic, what stage the blinds are? In Mosiac we could choose whether it was sideways or up/down.. Now we only got 3 buttons (up, stop, down). No % indication of blind stage.. ?
You can attach Position status object to the widget. In Plan view you can use additional icons to display a different icon depending on the status value.
But not in Tile View?
Show value on the opposite side of widget's title
Yeah, okay. But no graphical feedback.. Thanks for the answer Smile
Is it possible to lock the menu on the left, så that it always is visible?
See General settings - Menu display
Sorry, I dont see that?...
This is option for Plan, for Tile this is set to auto hide otherwise you will see nothing on mobile.
(02.04.2026, 11:31)admin Wrote: Do you mean when short/long press option is enabled?
yes
