Threads: 10
hi,
How can I display a formatted string expression?
there is Only "Numeric value display". Bu i need "string value display". (250 byte string)
Threads: 48
Use Text input widget in read-only mode.
Threads: 52
Is it possible change the color of the text (read only option) from the value of an other boolean object ?
KNX Advanced Partner + Tutor
Threads: 30
Threads: 48
You don't need any scripts. Simply use Switch widget in read-only mode. Set Display mode to "Value", Shape to "No shape". Adjust On/Off state text and color as needed.
