Default Icon and Custom Icon Control Differences
In the new visu graphics system, the main difference between default icons and custom icons is that with default icons we can change the color and background based on the point value, whereas this is not possible with custom icons.
We have our own custom icon library in SVG format. If we adapt the internal structure of our SVGs to match the SVG structure used by the default icons, would it be possible to enable color and background changes for our custom SVG library as well?
If so, could you please provide:
  • A standard SVG internal structure/template used by default icons, and
  • A description of the key rules or points to pay attention to for proper standardization?
Thank you in advance.
At this moment it's not possible because built-in SVG icons are placed directly into the page while custom icons are loaded using <img> tag. It should be possible to load custom icons differently but we need to test this first. For coloring simply use fill="currentColor" in your SVGs.
Check this: https://forum.logicmachine.net/showthrea...1#pid41181
