scheduler thermostat
Good morning, I need to activate a scheduler on Visu to create a programmable thermostat like this:
Monday at 10:00 am, Comfort
on
Monday at 12:00 pm, Standby on, etc.
(22.02.2026, 09:37)dezza@sdme.it Wrote: Good morning, I need to activate a scheduler on Visu to create a programmable thermostat like this:
on
Hi, first of all you need to create a virtual object on off schedule. In this way you can enable or disable the schedule by VISU.
Then in schedule folder in configuration you can set up your time.
In VISU using the widget link it is possible add your schedule in your project.
Best regards Cristian
on
Ottimo, ma riusciamo ad aprire la schedulazione direttamente sul tag e non sulla pagina principale? magari in un popup
on
Yes there's a widget in new VISU of I'm not wronging it could be the link widget
BR Cristian
You can use Frame to display it directly in Visu.
