KNX/TP: Transmitter Error (send 0 receive 1)
After changing from LM4 to LM5 I've got such error:
Script name "system": KNX/TP: Transmitter Error (send 0 receive 1)
HW: LM5 Lite + Ext (i.MX6)
SW: 20251204
What does that mean and what should I do?
thanks
This can show when many telegrams are sent at once or bus is very busy. This is just direct report from KNX chip. Check if some scripts/schedulers do not activate something at the same time. If it just happened once you can ignore this.
Thanks!
is there any way to get LM CPU Temperature?
Use this:
temp = io.readfile('/sys/devices/platform/soc/2100000.bus/2198000.adc/iio:device0/in_temp_input')
temp = tonumber(temp) / 1000
log(temp)
