Threads: 4
Hi, I have a few issues with the new visualization:
- When you change an option inside a "Select Value" popup widget, the popup closes automatically.
- When creating a frame in the plan view to display schedules, the default size is very small. If you scale it, it doesn’t scale properly and you have to adjust it manually for the screen. However, the screen size changes depending on the device (tablet, mobile, computer), but the widget size does not adapt. In tile view, it is also not possible to change the popup size.
- Is there any way to lock part of a custom widget so it cannot be seen or modified?
Do you know any solutions?
Thank you in advance for your help.
Threads: 31
1. This is by design, once you selected your option window will close to avoid too many clicks.
2. Not sure I understand this correctly, you can change the frame size as you want on plan.
3. Not possible.
Threads: 4
(05.03.2026, 10:57)Daniel Wrote: 1. This is by design, once you selected your option window will close to avoid too many clicks.
3. Not possible.
- I understand that the popup closes by design after selecting an option. However, in some cases it would be useful if it stayed open, for example when you need to change several values quickly inside the same popup.
- About the frame in the plan view: yes, the frame size can be changed. The issue is that when I scale it to make it larger, it does not adapt automatically to different screen sizes (tablet, mobile, computer). So if I make it fit on a computer screen, when I open it on a tablet it becomes too large to be displayed correctly.
Threads: 31
1. The case you define is very rare in our opining and we are not planing to change this. You can make custom widget with send fixed values.
2. Visu cannot control what is inside the frame, it can only scale the frame itself. As for Scheduler we are planing to make dedicated widget for it and this will scale as the rest of the visu.
Threads: 68
(05.03.2026, 11:18)Daniel Wrote: 1. The case you define is very rare in our opining and we are not planing to change this. You can make custom widget with send fixed values.
I think that case 1 is not rare...
For example, if the default thermostat control does not fit a specific project and a custom one must be created, if you want to put a comfort/standby/night mode change control with a drop-down menu, when changing mode the entire widget closes... and it doesn't look good at all...
Doing it by sending fixed values means that much more space is needed...
Threads: 31
This is actually a bug
Threads: 4
Hi, I have another problem with the circular light widget. I want to use it in compact mode, but when I open it, another strange widget appears.
Do you know why this happens?
Threads: 31
This is not a bug, this is by design. The Light and circular light widget are special with many different settings for complex light control. The popup is predefined based on the settings and no you will not see circular slider there. If you want to have normal circular slider in compact mode scroll down for Circular slider widget.
Threads: 4
(12.03.2026, 09:20)Daniel Wrote: This is not a bug, this is by design. The Light and circular light widget are special with many different settings for complex light control. The popup is predefined based on the settings and no you will not see circular slider there. If you want to have normal circular slider in compact mode scroll down for Circular slider widget. You are right, but with that option there is no switch to turn the light on or off. In the end, I would have to create a custom widget. Or do you have another option?
It would be nice if the circular light widget could also be used in compact mode.
Threads: 31
On Circular slider you can enable step buttons and set them to work as Min/Max which is On/Off
Threads: 68
(13.03.2026, 08:17)Daniel Wrote: On Circular slider you can enable step buttons and set them to work as Min/Max which is On/Off
Hi, I've the same problem...
It's very usual in KNX that in dimmed lights to use On/Off object to switch the light to its last value, using circular light it's not possible...
And the widget called circular light is circular for all options except for the "simple"dimmed light... I think that it should be more intuitive if in this mode the off/on button is where the temperature colour (or rgb colour) change is and mantain the circular wheel to dimm...
Threads: 4
Hi, I have a question.
Is there an option to display a 250-byte string in the visualization?
Also, is there a way to import custom fonts?
Threads: 31
Use text input and set it to read-only if you just want to display. Set Display mode as needed.
Threads: 4
(26.03.2026, 08:08)Daniel Wrote: Use text input and set it to read-only if you just want to display. Set Display mode as needed.
Okay, that works, thanks. And can I import different fonts?
Threads: 48
You can use web fonts via Custom CSS. Make sure that @import rule is placed before any other CSS.
Code: @import url('https://fonts.googleapis.com/css2?family=PT+Sans:ital,wght@0,400;0,700;1,400;1,700&display=swap');
body {
font-family: "PT Sans", sans-serif;
