Today, 09:57
If I open a port through the router, could I connect to a logic machine via the WAN IP address?
Puerto Externo = WAN port
Puerto Interno = LAN port
Remote connection via http server
Today, 09:57
Puerto Externo = WAN port Puerto Interno = LAN port
11 hours ago
What I want is to access the SCADA system, that is, the logic machine, through its static IP address. The problem I've encountered is that the network card I installed in the router doesn't have a static IP address, so the HTTP or HTTPS option won't work.
I'm looking at the VPN option as a zero-tier solution.
10 hours ago
Have you configured a valid gateway and DNS in Network > Interfaces > eth0?
10 hours ago
Your gateway IP is in another subnet, this setup won't work.
Either the gateway is wrong and should be 192.168.0.1 or LM IP must be in the 192.168.1.x range.
9 hours ago
You are right, my device's gateway was my router's ip, now i see my LM in zerotier
