Threads: 101
HW: LM5 Lite + Ext (i.MX6)
SW: 20240426
ETS: 6.4.0
When programming a device with ETS i received an error: connection closed by remote device 2.x.x (my new buttons).
How to solve this?
- It is possible to program the individual address
- It is not possible to program the application, also not the short option
Threads: 30
What exactly is this new button you have? Is it maybe data secure?
Threads: 101
Berker S8014xxx0, not secure
Threads: 30
I just tried ETS 6.4 on my instalation and it worked all fine.
Is LM KNX address from the same line you trying to download?
Threads: 101
Yes same line, i can program the individual address en 99/100 times the app download doesn't work.
Threads: 30
What about LM itself, what is the load and how is the bus traffic?
Threads: 101
cpu/io 0.23 0.23 0.12, memory 9%, knx/tp op
very low bus traffic.
Threads: 30
Try rebooting LM, did you try any other device not just this PB?
Threads: 101
I have rebooted the LM multiple times and tested other settings, but without success.
- I tested a USB programming interface and then it works right away.
- I cannot program other KNX devices either.
- I also have another LM located in a different part of the building, with its own KNX installation. It doesn't work there either. Both installations are behind a Mikrotik router. Could that have something to do with it?
Threads: 30
Are you not connected to the same lan what LM is only via the microtic router?
Threads: 101
Lan A:
Microtik switch A
SW: 20240426
Lan B:
Microtik switch B
SW: 20240426
Lan A + B switches connected on the same Mikrotik Router
Lan A + B LM's connected over multicast IP
Threads: 30
Are you connected to switch A when trying to download to LM A?
