email via application
Hello, one of the features of the application we are developing is to periodically send an email with a CSV report attached. We implemented this using a script, and it works very successfully.
However, when we tried to embed this functionality into the application's index.lp file, we were unable to send even a plain email, let alone one with an attachment. This is the same Logic Machine where the email works perfectly fine via scripts.
I am sharing the working script below. How can we properly integrate this into the application?
--Gmail (smtp) username user = '***@gmail.com' --Gmail (smtp) password password = '***' --From from = '<' .. user .. '>' alias_from = 'gonderenhesap@gmail.com' --REceiver to = '***@***.com' alias_to = '***@***.com' --Email subject subjectpart1 = 'Alarmlar' subjectpart2 = 'Logic Machine Tarafindan Gonderildi' --Message epilogue = 'Mesajin sonu' -- Get all alerts from DB alerts_table = db:getall('SELECT * FROM alerts') -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "ID", "ALERT", "ADDED TO LIST") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through alerts_table for _, alerts in ipairs(alerts_table) do   -- format csv row   csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%x %X", alerts.alerttime))   -- add to buffer   table.insert(buffer, csv) end --Create table to include mail settings local settings = {     from = from,     rcpt = to,     user = user,     password = password,     server = 'smtp.gmail.com',     port = 465,     secure = 'sslv23', } --Create attachment inside FTP server src = 'AlertExport_'.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv' dst = '/home/ftp/' .. src log(io.writefile(dst, buffer)) log("file created") log(dst) --Create subject subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2 --Load required modules to send email with attachment local smtp = require("socket.smtp") local mime = require("mime") local ltn12 = require("ltn12") --Create e-mail header settings.source = smtp.message{ headers = {           from = '' .. alias_from .. ' ' .. from .. '',           to = '' .. alias_to .. ' ' .. to .. '',           subject = subject }, --Load attachment inside body    body = { preamble = "", [1] = {          headers = {           ["content-type"] = 'text/plain',           ["content-disposition"] = 'attachment; filename="'..src..'"',           ["content-description"] = '.. src ..',           ["content-transfer-encoding"] = "BASE64",         },         body = ltn12.source.chain(           ltn12.source.file(io.open(dst, "rb")),           ltn12.filter.chain(           mime.encode("base64"),           mime.wrap()         )       )     },       epilogue = epilogue   } } --Send the email r, e = smtp.send(settings) --Create alert when sending gives an error with error message if (e) then   log (e)   log (r) end -- FTP Uploader -------------------------------------------------------------------------- -- local ftp = require("socket.ftp") -- local ltn12 = require("ltn12") -- f, e = ftp.put{ --  host = "ftp.test.tv.tr", --  user = "fgtest@test.tv.tr", --  password = «ftpsifresi", --  command = "appe", --  argument = src, --  source = ltn12.source.file(io.open(dst, "r")) -- } --Delete created file from ftp folder inside HL os.remove(dst)
You cannot use Luasocket library for sending emails from the web server context (apps).
Attached is a modified single file version of this library: https://github.com/GUI/lua-resty-mail/
It should work from both scripts and apps. You can create a user library named mail and load it like this:
local mail = require('user.mail')
Check the link above for examples and options reference.
.lua   mail.lua (Size: 14.86 KB / Downloads: 4)
Hi , i need help for that. For test purposes , i created a simple mailtest app. In , data/mailtest i have index.lp and icon.png. In,  libs/mailtest i have mail_lib.lua ( new library you shared.) and i can't send email i get connect failure: timeout . I shared files. Can you check it out ?
.lua   mail_lib.lua (Size: 14.9 KB / Downloads: 5)
.lp   index.lp (Size: 3.86 KB / Downloads: 8)
Remove timeout = 10 from index.lp and try again.
