KNX/TP: Transmitter Error (send 0 receive 1)
After changing from LM4 to LM5 I've got such error:
Script name "system": KNX/TP: Transmitter Error (send 0 receive 1)
HW: LM5 Lite + Ext (i.MX6)
SW: 20251204
What does that mean and what should I do?
thanks
This can show when many telegrams are sent at once or bus is very busy. This is just direct report from KNX chip. Check if some scripts/schedulers do not activate something at the same time. If it just happened once you can ignore this.
Thanks!
is there any way to get LM CPU Temperature?
Use this:
temp = io.readfile('/sys/devices/platform/soc/2100000.bus/2198000.adc/iio:device0/in_temp_input')
temp = tonumber(temp) / 1000
log(temp)
Still getting warning on my new LM machine:
KNX/TP: Temperature Warning
Version: 20251204
CPU/IO: 0.90 0.69 0.41, Memory: 15%, KNX/TP: OK
BTW: I wish there would be an easier way to copy several error messages Smile
See this: https://forum.logicmachine.net/showthread.php?tid=6369
(01.04.2026, 06:56)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=6369
Thanks, I've read the thread.
In that example there were a lot repeats, in my LM - not so many (see attachment).
I can only catch repeating telegrams by monitoring ETS? No quicker option?
Thanks a lot!
You have a very low number of repeats so it's not a problem. Most likely the warning appears when LM is sending many telegrams at once.
You can install Group monitor app in LM and see all telegrams in real-time. It highlights a different kind of repeats - when the same value is sent multiple times.
The same advice applies:
You should either use virtual group addresses or disable "write to bus" option where applicable. In scripts use grp.update/grp.checkupdate for such group addresses. Use grp.checkwrite where possible to lower the bus traffic. Adjust send delta for Modbus devices if any.
In forum I've read that there is no option to export from LM group objects, is that right?
And thanks, I really appreciate your quick and informative replies!
There's a script that creates CSV for ETS: https://forum.logicmachine.net/showthrea...1#pid32601
Make sure to backup your ETS project before importing CSV.
ETS does not handle custom data types that are used in LM like 255 byte string and 4 byte RGBW. Importing such objects can crash your ETS project.
