Threads: 81
Hello Dears,
I tried to backup SL, but when downloaded its 0mb size (the archive is either in unknown format or damaged)
Best Regards,
Threads: 48
Most likely the problem is with too many big images and/or using the whole trends storage space. Device runs out of memory when creating a backup due to this.
Things to check:
- See if all images/icons are really needed
- Reduce image resolution where possible
- Use JPG with lower quality instead of PNG for photos and complex images
- Don't use BMP, use PNG for simple floor plans
Threads: 81
I think its related to trend size, While this isĀ an old broject with same images nothing added recently
how to solve the trend log size issue
Best Regards,
Threads: 48
You can only delete some trends. Have you verified that there are no large images? Send a screenshot of partitions usage from System config - Status - System status - Partitions tab.
Threads: 48
It's a very old device with lower RAM amount compared to current hardware. Unfortunately the only option of making a backup is to remove the SD card and make a full disc image. Since it's an old device replacing the SD card is recommended.
