26.01.2026, 07:25 (This post was last modified: 26.01.2026, 12:30 by toujour.)
Hi, what is the better way to control a blind from the new Visu ?
When I use this control
I have a problem with the slats ( I think the bit stop doesn't work properly. I can't open and close slats by singol tap on the button.....the stop is always in the same direction).
26.01.2026, 12:28 (This post was last modified: 26.01.2026, 12:30 by toujour.)
With the shutters the bit stop always works (0 or 1 value).
With the blinds the bit stop has a sense ( 0 --> open slats by one step , 1 --> close slats by one step ).
for example there are 10 steps to open/close the slats completely
The best think is with short and long command (is it possible ?...or I have to use javascript).
Otherwise...How can I change the value of the stop ?
It is not about blind status, it is about, is it moving or did it stop. There is position status object which can display position in %, use icon and value.
Is there no widget on Visu that displays in graphic, what stage the blinds are? In Mosiac we could choose whether it was sideways or up/down.. Now we only got 3 buttons (up, stop, down). No % indication of blind stage.. ?
You can attach Position status object to the widget. In Plan view you can use additional icons to display a different icon depending on the status value.
