blind control on Visu
#21
(20.04.2026, 10:05)PolymorphedCust Wrote: But not in Tile View?
Hi Daniel,
I would like to show position shutter status on Tile. In Mosaic we have slider but in Visu it seems there is not a proper widget for 1 byte position.
I could you use widget vertical slider for displaying the status but there is only the position of the "cursor dot".
There is no difference in color from the shutter raised or lowered.
Have you got any idea?
See this option in Tile settings: Show value on the opposite side of widget's title. This will alos work for movment widget when Position status object is set.
(8 hours ago)Daniel Wrote: See this option in Tile settings: Show value on the opposite side of widget's title. This will alos work for movment widget when Position status object is set.
Ho Daniel,
Sorry but I do not know what you mean. Are you referring to Movement 1 bit widget settings?
Any widget with byte status, this is general setting for Tile.
