blind control on Visu
#21
(20.04.2026, 10:05)PolymorphedCust Wrote: But not in Tile View?
Hi Daniel,
I would like to show position shutter status on Tile. In Mosaic we have slider but in Visu it seems there is not a proper widget for 1 byte position.
I could you use widget vertical slider for displaying the status but there is only the position of the "cursor dot".
There is no difference in color from the shutter raised or lowered.
Have you got any idea?
See this option in Tile settings: Show value on the opposite side of widget's title. This will alos work for movment widget when Position status object is set.
(11.05.2026, 07:07)Daniel Wrote: See this option in Tile settings: Show value on the opposite side of widget's title. This will alos work for movment widget when Position status object is set.
Ho Daniel,
Sorry but I do not know what you mean. Are you referring to Movement 1 bit widget settings?
Any widget with byte status, this is general setting for Tile.
Ciao Daniel,
now I understand why in my widget is not shown. Because I use the widget in "Movement 1 bit" in a Custom Widget. Settings are not the same.
Question is that sometimes customers forget the meaning of 0% and 100% (open or closed?). Even if I explain them I know that after 6 months they forget it.
In any case I use this solution and I personalise the meaning showing the label "open" at 0% and closed at 100%.
Please consider that a graphical widget could be the best.  Wink
(11.05.2026, 20:30)Domoticatorino Wrote: Ciao Daniel,
Sorry Daniel, but how can I customize the value of the status byte when level is 0% and 100%? As I wrote above I would like write open when value is 0% and closed when it is 100%. Thanks.
Right now this is not possible but this is actually a bug, we will fix it in upcoming version.
(13.05.2026, 07:22)Daniel Wrote: Right now this is not possible but this is actually a bug, we will fix it in upcoming version.
Thank Daniel, Have you got an idea when?
Beta version should be this week but stable version might take some weeks.
Additional icons/values will display custom text now.
https://forum.logicmachine.net/showthrea...3#pid42143
(Yesterday, 09:40)Daniel Wrote: Additional icons/values will display custom text now.
Great! Thanks
