Email routing to SIM
Good morning
I have reactors in which I installed the SIM. The reactor doesn't have direct access to the internet because it's on a segregated network, which guarantees me protected and controlled access from the customer's company PC. I use the SIM to send SMS messages. Is there a way to force the reactor to send emails using the SIM?
Thank you very much.
Then you need to enable 3G/4G connectivity. Local LM access will be limited to the same subnetwork because mobile network gateway will be used.
(11 hours ago)admin Wrote: Then you need to enable 3G/4G connectivity. Local LM access will be limited to the same subnetwork because mobile network gateway will be used.
There is no way to work around the problem: since I need to leave the reactor reachable from the client's network via firewalls etc. etc.
