High CPU load on Modbus profile
Hi !
We are using a Spacelynk to read a lot of variables (140) from a Schneider PLC with a profile json.
If I set the poll interval between 1 and 5 seconds, the CPU is very overloaded and everything seems to be slow:
It only gets better (less than 1.0) with more than 6-7 seconds. But I need a faster polling rate for this application.
The profile is communicating fine with the PLC.
Any idea how can we overcome this issue ?
I attach the json used
.json   PLC_Example.json (Size: 22.96 KB / Downloads: 5)
Use Value send delta: to not write same value all over to the bus and do not write to bus what is not necesssary.
(21.05.2026, 15:34)Daniel Wrote: Use Value send delta: to not write same value all over to the bus and do not write to bus what is not necesssary.
Thank you for your feedback.
The most of variables are read only.
You are talking about this value send delta or other thing related with json profile ?
what is this daemon.lua ?
The Apti3 is SE app and it seems this is your problem, contact SE.
If I remember well there was some option there to disable logging, this might be reason for high reddis cpu values.
We can't help you with this.
