26.05.2026, 18:53
Are you sure it is Zigbee? If it yes then try to pair it, this proces will wiok if it is Zigbee. Paste device information as above.
Zigbee gateway integration
26.05.2026, 18:53
27.05.2026, 08:55
(26.05.2026, 18:53)Daniel Wrote: Are you sure it is Zigbee? If it yes then try to pair it, this proces will wirk if it is Zigbee. Paste device information as above. I’d say it’s Zigbee, but now you’ve made me question that. If it weren’t Zigbee, is there any way to integrate the Netatmo solution into LM? I’ll find out which devices they are and post them here.
27.05.2026, 09:04
Study this thread
https://forum.logicmachine.net/showthrea...d=84#pid84
Yesterday, 17:45
I need help with the following.
I'm trying to add and control the Aqara Roller Shade Driver E1 device. https://www.aqara.com/eu/product/roller-shade-driver-e1 I can assign group addresses, but the device doesn't respond when I change its status. When the device’s physical button is pressed, it returns values in the monitor section. Device found: Manufacturer: LUMI Model: lumi.curtain.acn002 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - DeviceTempCfg (2) - Identify (3) - Groups (4) - Scenes (5) - OnOff (6) - Alarms (9) - AnalogOutput (13) - MultistateOutput (19) - ClosuresWindowCovering (258) Output clusters - Time (10) - Ota (25) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33) Reported attributes - windowcoverlift: 0
2 hours ago
Is there a user-defined/manual way to add a Zigbee device (including its functions and group assignments) to the devices list even if it isn't in the list of supported devices?
For example (the device was found but I can't use its functions): Manufacturer: LUMI Model: lumi.motion.ac02 Firmware version: 0.0.0_0010 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - ManuSpecificAqaraOpple (64704) Output clusters - Identify (3) - Ota (25) - ManuSpecificAqaraOpple (64704) |
