Visu updates / changelog (20260618 - beta)
Version 20260128 (stable)
Allow closing widget pop-up window by clicking outside of it
Add short/long option to movement widget (emulates KNX shutter actuator behavior)
Fix "no shape" icon display consistency between different widgets
Rework additional icon range matching logic:
- Value matching rules: Min ≤ Value ≤ Max or Value = Min if Max is not set
- Matching is be done in reverse order. If ranges overlap (previous max = next min) then the latter will be used
Custom JS:
- Add Visu active-plan-change event
- Add widget.listen(ga, cb) method
Widget wishlist: https://forum.logicmachine.net/showthread.php?tid=5875
Feature requests: https://forum.logicmachine.net/showthread.php?tid=5692
Bug reports: https://forum.logicmachine.net/showthread.php?tid=5892
Custom JS reference: https://kb.logicmachine.net/misc/visu/
Video tutorials: https://forum.logicmachine.net/showthread.php?tid=6238
Manuals: https://logicmachine.net/manuals/visu-20251120.pdf
Version 20260205 (beta)
Due to many changes this version is first published as a package and is not available in the app store.
Cloud Visu won't be updated until a new stable version is published.
Most notable changes:
- Fix for older browsers
- Plan "Show" option is ignored if View mode is either "Plan view only" or "Tile view only"
- Page zoom via touch pinch can be disabled in Global appearance settings
- Value select widget selection list can be configured to always open in a pop-up window
- Tile view Category widget can be duplicated (only the Category widget itself, without any child widgets)
- "Invert" option added to Switch widget
- Custom SVG icons can now be colorized by enabling "Apply color to custom SVG icons" in Global appearance settings
For this to work, SVG icon must be prepared accordingly:
1. Add id="root" to the <svg> element
2. Add fill="currentColor" to the <svg> element
3. Use viewBox for sizing, do not use width and height
SVG icons without these modifications won't be displayed.
Example icon attached.
.svg   key.svg (Size: 745 bytes / Downloads: 69)
Version 20260319 (beta)
- Tile view scaling has been reworked, new options added to general settings
- Circular slider active zone has been reduced to minimize accidental value changes
- Circular light widget now displays a circular slider in a pop-up window instead of a regular slider
- Fixed first plan display in user mode when either tile or plan mode only is selected
Version 20260323 (stable / old beta)
This version fixes a bug when plan links are not visible if global view mode is set to either Plan or Tile view only.
Version 20260417 (beta)
- Added new Air conditioner widget
- Added "Invert" option to Toggle widget
- Added "Stop on release" option to Movement widget
Version 20260514 (beta)
- New icons added
- Image size limit of 2MB
- Fix for Additional icons/values on Movement widget
- Fix for object appearance on custom widget.
Version 20260604 (stable)
Bug fixes:
- Fix thermostat widget mode selection always showing all mode options
- Fix temperature status units for air conditioner / thermostat widgets
- Fix air conditioner status icon display when a custom icon is used
Version 20260618 (beta)
- New KNX scene widget - works as typical KNX scene where on short press the scene is recalled and on long press the learn scene command is sent, there are also optional notifications.
- Universal Short/long press widget - allows of fully configured actions for short and long press.
Short press actions:
Long press actions:
.ipk   visu-20260618-2.ipk (Size: 812.03 KB / Downloads: 3)
