Zwave - Fibaro Motion Sensor
#21
Z-wave logo is shown behind the "RS485 / USB etc." external gateways cube Smile
Meaning, by having for example Serial to Z-wave gateway, it can be easily added through scripting by integrator himself.
Thumbs Up
(08.10.2015, 12:48)edgars Wrote: Z-wave logo is shown behind the "RS485 / USB etc." external gateways cube Smile
Ok, nice to know  Smile
I am ready for beta testing, Customers are asking for this
By when can we expect to have a first version of the z-wave gateway and Bluetooth?
Probably by the end of the year. Which Bluetooth devices are you planning to connect?
I am planning to use it for a Customer with solar panels, I need to read out the sma inverter
I could find a bypass for now using an open source project domoticz that can handle Bluetooth, z-wave,... The issue that I am facing is easy bridging domoticz or openhab with logic machine. I see two options that open up your platform with other platforms
- mqtt, but then there would be need to easy subscribe to messsage types and handeling of the messsage formats (see node red)
- incomming and ontging rest services calls like you have for knx GROUP adresses with custom scripts behind the services (see weinzierl baos interface)
Is any of the above two options already possible/easy to add?
Adding it through scripts maybe feasible, but seems quite cumbersome
Do you have full specification of where the inverter data is stored (handle id / uuid) and what is the data type? Our BLE mapper has profiles so end users don't have to write any code, but each profile is basically a script because there's no unified way of storing data in BLE, so each device from each manufacturer requires different approach.
As for remote services you can always add an event script and use standard remote services. It is also possible to use Lua scripts that are accessible through the web server, but we are still preparing full documentation and examples for that.
Thanks for your reply
I was planning to use the following open source project for the interfacing
https://github.com/ez2X8pk61DHkdztgFT6O/...th-reader2
It seems just like a plain serial protocol
The packet layout can be found here
http://blog.jamesball.co.uk/2013/02/sma-...ormat.html
As for the Remote services, i Will have to dig more into the capabilities of lua.
I hope that you can add something for this in the future like a generic rest interface behind which we could at scripts for example
-Mylogicmachine:80/api/universalInput/1?value=on (http put)
-Mylogicmachine:80/api/universalOutput/1 (http get)
behind the call custom scripts like you have for the universal input/outputs
Hello
I managed to integrate zwave, rf devices, .... by using domoticz as gateway, for now I only use it for switching zwave and rf devices and it works pretty well
domoticz you find here (I installed it on a synology nas):
https://www.domoticz.com/
below my user library
DOMOTICZ_IP = '192.168.0.12' DOMOTICZ_PORT = '8084' DOMOTICZ_ID_BASEMENT_COMPRESSOR = '23' DOMOTICZ_ID_LIVINGROOM_READING_LIGHT = '215' DOMOTICZ_ID_LIVINGROOM_VENTILATOR = '102' KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF = '8/0/0' KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF_STATUS = '8/0/1' KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF = '8/1/0' KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF_STATUS = '8/1/1' KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF = '8/1/2' KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS = '8/1/3' -- write value to knx only if value changed function writeKNX(group, value, default, typ)  local key,time   --  time = os.microtime() --  log('writeKNX(group, value, typ)',group,value,typ)  key = 'KNX_GRP_' .. string.gsub(group, "/", "_") --  log('writeKNX(group, value, typ)',key)  if ((storage.get(key, default)) ~= value) then --    log('now writing writeKNX(group, value, typ)',key, group, value)    storage.set(key, value)    grp.write(group, value, typ)  end end -- toggle on / off function domoticzSwitch(host, port, domoticzId, value)  local time --  time = os.microtime() --  log('domoticzSwitch(host, port, domoticzId, value)',host, port, domoticzId, value)  if (value == true) then    domoticzCmd(host, port, domoticzId, 'switchlight', 'On')  else    domoticzCmd(host, port, domoticzId, 'switchlight', 'Off')  end   --  time = os.microtime() - time --  log('domoticzSwitch(host, port)',host, port, domoticzId, value, time) end -- get On Off Status function domoticzGetSwitchStatus(host, port, domoticzId)  local time, status --  time = os.microtime() --  log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId)  status = domoticzStatus(host,port,domoticzId)  result =  (status.result[1].Status == "On")   --  time = os.microtime() - time --  log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId, result, time)  return result end -- send command to domoticz function domoticzCmd(host, port, domoticzId, domoticzCmd, cmdParam)  local http, request,r, c, h --  time = os.microtime() --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam)     -- load the http module     local http = require("socket.http")  request = "http://" .. host .. ":" .. port .. "/json.htm?type=command&param=" .. domoticzCmd .. "&idx=" .. domoticzId .. "&switchcmd=" .. cmdParam --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, request)     -- connect to server  r, c, h = http.request (request) --  time = os.microtime() - time --  log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, r, c, h, time) end -- retrieve a status from domoticz function domoticzStatus(host, port, domoticzId)  local http, request,r, c, h --  time = os.microtime() --  log('domoticzStatus', host, port, domoticzId)  -- build the http request     local http = require("socket.http")  request = "http://" .. host .. ":" .. port .. "/json.htm?type=devices&rid=" .. domoticzId-- --  log('domoticzStatus', host, port, domoticzId, request)  -- execute the http request  r, c, h = http.request (request) --  time = os.microtime() - time --  log('domoticzStatus', host, port, domoticzId, r, c, h, time)  -- decode the json object  local json = require("json")    local statusobject = json.pdecode(r)  return statusobject end
here a trigger to switch a device based a knx event
SCRIPT = 'user.library' lib = require(SCRIPT) if not lib then alert('Event ' .. event .. ' not handled: script ' .. SCRIPT .. ' missing') os.sleep(60) return end -- object mapped to this event must have its data type set value = event.getvalue() -- toggle on/off domoticzSwitch(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR, value) -- only write on changed data writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS, value, false, dt.bool)
finally my deamon script to ensure that the knx status is correctly set even if I use domoticz or my zwave remote
SCRIPT = 'user.library' lib = require(SCRIPT) if not lib then alert('Event ' .. event .. ' not handled: script ' .. SCRIPT .. ' missing') os.sleep(60) return end ----------------------------------- -- determine the domticz status ----------------------------------- -- basement bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_BASEMENT_COMPRESSOR) writeKNX(KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF, bStatus, false, dt.bool) -- livingroom -- reading light bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_READING_LIGHT) -- only write on changed data --writeKNX(KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF, bStatus, false, dt.bool) -- ventilator bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR) -- only write on changed data --writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF, value, false, dt.bool)
I am sure code could be cleaner but I am still learning lua
Enjoy Smile
Next step let a mobotix cam trigger the opening/closing of doors, but manage the opening hours per user through logic machine
This line will do nothing because if require fails it produces an error and script execution stops.
(26.11.2015, 07:02)admin Wrote: This line will do nothing because if require fails it produces an error and script execution stops.
ok thanks
(11.11.2015, 07:07)admin Wrote: Probably by the end of the year. Which Bluetooth devices are you planning to connect?
And? can we get this as a christmas present? Smile
Is there already more information? when can we expect it and use this nice feature?
Hello
Any info regarding the new firmware?
When can we expect it?
Nicky
it is planned for FEB 2016.
Sorry for delay.
(19.01.2016, 09:00)edgars Wrote: it is planned for FEB 2016.
Sorry for delay.
is the new firmware planned for feb 2016 or the zwave support, or both Smile ?
ZWave is planned to come on FEB.
New firmware (at least beta version) is planned for JAN Smile
Thanks for the update
As you notice we look forward to it :-)
Some screenshots while waiting for the final release of ZWave app for LogicMachine Wink
(29.01.2016, 11:49)edgars Wrote: Some screenshots while waiting for the final release of ZWave app for LogicMachine Wink
i can't wait Smile
