Threads: 43
I would like to use this thread for users to give feedback of functions I would like to have in future LM software.
1: multiligual, the possibility to change the english language in visual screens to own language would be great. Like start page, user visu, touch visu, schedular and trend pages. The system and programming pages is ok with english. I would gladly help with the norwegian translate.
2: as earlier mentioned the modbus mapper should have a possibility to add or update profiles for working devices. Had ro delete an working profile multiple times to add a couple of adresses extra. Or the possibility to map knx adress in json file so it doesnt have to be done manualy.
3:in trend setup we can chose 1 minute data. can this be used to make trend in the trend menu?
More to come...
Passivpluss
Threads: 45
1. Next firmware will have some translations added. We can send you files for translation if you are really up to creating Norwegian language files.
2. That's too complicated technically. Profile is used only when creating new devices. It is converted to internal format and linked to the new device. This means that changing/deleting profile does not affect the device. Mapping inside the profile can be good for development but we have another solution in the works. There will be a separate form that will allow to read register/coil values with a specified data format. It can even be possible to generate JSON chunk from that form. This way you don't have to map to group addresses while developing.
3. We are working on this feature, but most probably it will have 5-minute interval as 1-minute requires quite a lot of space to store all of the data.
Threads: 43
1 Depends on how much work it is, as I got my hands full at the moment. But in a couple of months I can make it happen
2 If you mean that one can add a register in the mapping window, that would be great. We got the possibillty to delete but not add at the moment.
5 min interval is plenty  Hoping it will be integrated at next firmware, when is it due?
Threads: 161
(20.07.2015, 21:30)PassivPluss Wrote: 1 Depends on how much work it is, as I got my hands full at the moment. But in a couple of months I can make it happen
I can help you with Polish translation  of device and manual.
Threads: 29
I could help with Spanish and/or German
Threads: 100
thanks guys!
I think we have Spanish and German translations already, will check on Polish and in case it is missing, will email translation file
Threads: 43
Threads: 43
Editing or adding many objects is complicated. Is it possible to make a export/import function to csv or excel?
The touch visualising is messy as there is no way of dividing objects or choose the order?
Threads: 6
25.08.2015, 15:01
(This post was last modified: 25.08.2015, 15:01 by Sandstrand.)
I would also like to suggest a mass edit function of visualisation parameters and custom values. Bit of a pain when I'd like to show "Enabled /disabled" instead of 0/1 to the end users in the visualisation and similar.
Threads: 45
Quote: I would also like to suggest a mass edit function of visualisation parameters and custom values. Bit of a pain when I'd like to show "Enabled /disabled" instead of 0/1 to the end users in the visualisation and similar.
Already planned for next release
Threads: 2
07.10.2015, 18:45
(This post was last modified: 07.10.2015, 18:45 by KingCanute.)
How is the Norwegian translation going? I offering my help with translating into norwegian unless it's done.
Threads: 100
KingCanute, I will email you the translation file.
Thanks for help!
Threads: 2
(08.10.2015, 13:04)edgars Wrote: KingCanute, I will email you the translation file.
Thanks for help!
I'll start with it during the weekend, going to take some time to get it done. There was alot of parameters to translate
Threads: 0
(08.10.2015, 14:16)KingCanute Wrote: (08.10.2015, 13:04)edgars Wrote: KingCanute, I will email you the translation file.
Thanks for help!
I'm happy to assist or proofread, if needed.
kes
Threads: 2
(11.10.2015, 20:20)kes Wrote: (08.10.2015, 14:16)KingCanute Wrote: (08.10.2015, 13:04)edgars Wrote: KingCanute, I will email you the translation file.
Thanks for help!
kes
I'm working with another person here on the forum, we're almost done with the translation. Missing about 30-40% before we're done.
But I could mail you the finished result, to have a third person view on the translation, incase we missed something.
Threads: 43
(12.10.2015, 12:56)KingCanute Wrote: (11.10.2015, 20:20)kes Wrote: (08.10.2015, 14:16)KingCanute Wrote: (08.10.2015, 13:04)edgars Wrote: KingCanute, I will email you the translation file.
Thanks for help!
kes
Great work
I havent had the chance to do anything so great that you can.
Blir fint å få alt på norsk
Threads: 5
Edgars,
If you would like a Dutch version, feel free to send me the translation file.
Kind regards,
George
Threads: 100
George,
thanks for your responsiveness, we have Dutch translation already
Threads: 2
And what about the French one ?
I could work on it ..
Threads: 100
mooselight, thanks, have it as well already
