19.01.2026, 13:27
You must use a domain name for HTTPS. IP can only be used for plain HTTP.
LM Home app (Andrоid/iOS starter)
19.01.2026, 13:27
19.01.2026, 13:42
19.01.2026, 13:49
Send your URL via PM but most likely we can't test it this way.
23.07.2026, 09:22
how can I get the apk? I have a lot of Phillips displays. Neither of them supports Goole play.
23.07.2026, 09:24
What is the Android version on this display?
23.07.2026, 14:06
23.07.2026, 14:51
12.08.2026, 06:03
The LMHome app works, but intermittently fails to launch:
Android - Samsung S24 smartphone The error is described as follows: When I close the application window (without using x), attempting to open it later results in the net::ERR_NAME_NOT_RESOLVED error message. Unfortunately, after this error message, LMHome will no longer launch. Every time I try to open/launch it (no matter what method), I get the message in the attachment. To launch the app, I have to clear it from the smartphone's memory, and then it works normally again. I should add that while the app hangs, the https://remote.logicmachine.net/logout link in the browser works, meaning it logs in to LMcloud.
12.08.2026, 07:02
Do you use local access or only cloud?
08.10.2026, 10:30
(11.12.2024, 16:11)Daniel Wrote: https://www.transfernow.net/dl/20241211ayd2WeZj i need the apk for a tablet running android 6 that has no playstore, can you provide the apk? |
