kamailio-imx6 install.lua: a failed download leaves an unrepairable partial install
Three observations about the installation method in
kb.logicmachine.net/integration/sip-server/, in case they are useful.
1. A FAILED DOWNLOAD LEAVES A PARTIAL INSTALL, SILENTLY
The script runs ten os.execute('opkg --force-depends install http://...')
calls and checks none of their return values. The guard at the top is
  if not io.exists('/etc/init.d/kamailio')
and /etc/init.d/kamailio is created by the fourth package (kamailio3) -
before the six module packages are installed.
So if a download fails after kamailio3 succeeds, the result is a running
Kamailio with some modules missing, and re-running the script does
nothing, because the guard is now satisfied. Nothing reports an error.
During my own installation one of the downloads did not complete
(dl.openrb.com was not responding at that moment - it is reachable again
now), which is how I noticed this.
This does not seem to be a one-off. While checking which module packages
exist, I made twelve sequential requests to the same host: eleven returned
a status (200 or 404) and one returned no response at all. That one was
kamailio3-mod-maxfwd, which does exist - it returned 200 when I retried
the identical request a minute later. I cannot rule out something on my
own network, but a single dropped request in a run of twelve is enough to
break an unchecked ten-step install.
Checking the exit status of each opkg call, or testing for one of the
module files instead of the init script, would make a retry actually
repair the install.
2. PLAIN HTTP, AND HTTPS CANNOT SIMPLY BE SUBSTITUTED
The packages are fetched over plain HTTP with no signature verification
and installed as root with --force-depends. Worth noting for anyone
thinking of just changing the URLs: the wget on the device is the BusyBox
build with no TLS support - it returns "not an http or ftp url" for an
https URL. So the client side would need attention too if TLS or signed
distribution were ever considered.
3. FIRMWARE UPGRADES
The article says the script must be executed again after each firmware
upgrade, which matches what I found - the device has no overlay
filesystem (/dev/root is mounted directly on /), so everything under / is
replaced. Is including Kamailio in the firmware image an option?
Re-running a script after every upgrade is workable for one device, but
combined with point 1 a partially repaired install would be easy to miss.
Thanks. Wink
