Scada-main for others users
Hello
I need 3 users to access the scada-main page, they need to edit knx objects for managingĀ a building remotely.
I don't want all of them to use the admin account for security reasons, but i haven't found how a new user can access this page. Can you help me ?
Not possible, there's only one admin user
Thanks for your quick answer !
How do others customers do it ?
Certain features like user management can be done via apps that normal users have access to. Why do you need to modify the object list after everything has been set up?
Sometimes we need to adjust certain values, and we also need to manually run certain scripts from time to time.
You should create a dedicated 'maintenance' page with restricted access just to the users and you should add all objects you need there. Event script is triggered just by writing a value to its trigger object. If you need to enable/disable a script then a simple event script will do it.
Thank you for your response !
By a maintenance page, you mean an app in the LM ?
And what if users need to add a new script ?
Thank you again for your time
No just a normal page on visu with restricted access to your users.
User cannot add script, only admin.
