LM Home app (Andrоid/iOS starter)
You must use a domain name for HTTPS. IP can only be used for plain HTTP.
(19.01.2026, 13:27)admin Wrote: You must use a domain name for HTTPS. IP can only be used for plain HTTP.
Using domain name doesn't work neither...
Is there any way that you can test it using our URL?
Send your URL via PM but most likely we can't test it this way.
how can I get the apk? I have a lot of Phillips displays. Neither of them supports Goole play.
What is the Android version on this display?
(23.07.2026, 09:24)Daniel Wrote: What is the Android version on this display?
Android version 13
https://www.transfernow.net/dl/20260723rQhzp6Es
The LMHome app works, but intermittently fails to launch:
Android - Samsung S24 smartphone
The error is described as follows:
When I close the application window (without using x), attempting to open it later results in the net::ERR_NAME_NOT_RESOLVED error message. Unfortunately, after this error message, LMHome will no longer launch.
Every time I try to open/launch it (no matter what method), I get the message in the attachment.
To launch the app, I have to clear it from the smartphone's memory, and then it works normally again. I should add that while the app hangs, the https://remote.logicmachine.net/logout link in the browser works, meaning it logs in to LMcloud.
Do you use local access or only cloud?
(11.12.2024, 16:11)Daniel Wrote: https://www.transfernow.net/dl/20241211ayd2WeZj
i need the apk for a tablet running android 6 that has no playstore, can you provide the apk?
LM Home works from android 10+
