Cannot load App List - DNS/Internet Check fails, but Ping works
Hello
I cannot load the application list on my LogicMachine. I get the error saying "Check that device has Internet connection and correct DNS configuration."
I have already checked the following (see attached screenshots):
DNS Settings: Set to 8.8.8.8 and 1.1.1.1.
Connectivity: I can successfully ping apps-v16-1.logicmachine.net from the device's Network Utilities.
If the ping is successful, why is the application list failing to load? Is there a specific port that is blocked, or does the App Store use a different URL?
Is this home or office network?
Do you have a firewall on your router?
Run this script once and see what you get in LM Logs tab.
sock = require('socket').tcp() sock:settimeout(1) res, err = sock:connect('apps-v16-1.logicmachine.net', 443) sock:close() if res then   log('connect OK') else   log('connect ERROR', err) end
