2 hours ago
I'd like to report an issue we have reproduced on two LM5 units, both running firmware 20251204.
Symptom
When ZeroTier is enabled and the LogicMachine is rebooted, the LM Home app can no longer find the device with auto-discovery. The LM is still reachable via its IP address in the browser. Only discovery stops working.
What we see on the LM
In the running processes list, after the reboot, avahi-daemon stays in the registering state and never moves to running:
avahi-daemon: registering [<hostname>.local]
We waited several minutes and it did not change.
Steps to reproduce
1. Enable ZeroTier.
2. Reboot the LM.
3. Avahi stays in "registering" and the LM is not found by LM Home auto-discovery.
What restores discovery
1. Disable ZeroTier.
2. Reboot the LM. Avahi now goes to "running" and LM Home finds the device again.
3. Re-enable ZeroTier without rebooting. Avahi stays "running" and discovery keeps working.
So the problem seems to appear only when the LM boots with ZeroTier already enabled. Enabling ZeroTier on a running system does not cause it. Disabling ZeroTier after the fact does not help either: avahi stays in "registering" until the next reboot.
Our guess is that Avahi doesn't complete its registration because of the ZeroTier interface coming up during boot, but we may be wrong.
The workaround above only lasts until the next reboot (e.g. after a power outage), so it's not practical on installed systems.
Questions
- Is this a known issue?
- Is a fix planned, for example restricting Avahi to the Ethernet interface or changing the startup order?
- Is there a recommended configuration to use ZeroTier and LM Home auto-discovery together?
Thanks in advance.
Symptom
Steps to reproduce
1. Enable ZeroTier.
2. Reboot the LM.
Questions
Thanks in advance.
