Backup and restoring Project
There is an option to backup the LM project as one file, and system configs as another file.
We've just experienced that restoring only the project file changes the KNX-connection settings in the system configuration.
Is this new, to implement only one backupfile is needed, or what is going on?
Thanks in advance !
This is by design as KNX settings are important to be transferred to a new device if you do a replacement otherwise you will have to manually copy the filter tables and KNX backbone. The latest firmware will also add BACnet settings to project backup.
It was like that since the beginning.
Okay, thanks for clarifying
