Widget and camera
HI !
When we install a camera in a widget, with the "auto open window" marked, it do not open automatically.
Has t he a solution for this issue ?
Regards.
JMM.
Jean-Marc
(26.06.2017, 11:10)JMM Wrote: HI !
Regards.
JMM.
You can create additional plan in Vis structure for camera and open it via Frame in needed plan.
Just tested it, and it works (firmware 20160927)
Hi !
I found a solution for auto opening a camera on widget via js :
$("#widget-15 > div").trigger('vclick');
This solution works perfect with quick visualization but not wih user visualisation !
I don't understand why Sad
Somebody would have an idea ?
Regards
JMM
Jean-Marc
You need to bind this event to the object that's opening the widget by using an additional CSS class (myclass):
$(function() {   $('.myclass').on('vclick', function() {     $("#widget-15 > div").trigger('vclick');   }); });
Thank you for the answer Admin !
My code was already bound to an event.
  // Open widget on KNX command   grp.listen('2/3/4', function(object, state) {     if (state == 'value' && object.value == true ) {         // Command to show widget       $("#widget-15").removeClass('hide');       $("#widget-15 > div").trigger('vclick');           }   }, true); // set to true to execute on same object value
It works perfect with quick visualization
but not with user visualization !
JMM.
Jean-Marc
You need to switch to the plan that has your widget first with showPlan(plan_id)
HI,
The script here is which works well, it is not certainly very academic.... I does not follow a specialist of the js!
JMM.
12345678910111213141516171819202122
// Init widget and change display and opacity   $("#widget-27").removeClass('hide');   $("#widget-27").css("display", "none").css("opacity", "0");    // Open widget on KNX command  grp.listen('2/3/4', function(object, state) {    if (state == 'value' && object.value == true ) {       // hide camera on widget In the case she would have remained open and triggered open button camera        $("#widget-27 > div").addClass('hide').trigger('vclick').css("pointer-events", "none");      // Command to show widget      $('#widget-27').css({'display':'block', 'opacity': '1', 'transform': 'perspective(800px)', 'top': '200px', 'left': '500px'});    }  }, true); // set to true to execute on same object value    // Close widget on KNX command  grp.listen('2/3/4', function(object, state) {    if (state == 'value' && object.value == false ) {       // Command to display widget       $("#widget-27").css("display", "none").css("opacity", "0");    }  }, true); // set to true to execute on same object value
Jean-Marc
