Threads: 99
Z-wave logo is shown behind the "RS485 / USB etc." external gateways cube
Meaning, by having for example Serial to Z-wave gateway, it can be easily added through scripting by integrator himself.
Threads: 2
08.10.2015, 14:14
(08.10.2015, 12:48) edgars Wrote: Z-wave logo is shown behind the "RS485 / USB etc." external gateways cube
Ok, nice to know
Threads: 13
I am ready for beta testing, Customers are asking for this
Threads: 13
By when can we expect to have a first version of the z-wave gateway and Bluetooth?
Threads: 46
Probably by the end of the year. Which Bluetooth devices are you planning to connect?
Threads: 13
I am planning to use it for a Customer with solar panels, I need to read out the sma inverter
I could find a bypass for now using an open source project domoticz that can handle Bluetooth, z-wave,... The issue that I am facing is easy bridging domoticz or openhab with logic machine. I see two options that open up your platform with other platforms
- mqtt, but then there would be need to easy subscribe to messsage types and handeling of the messsage formats (see node red)
- incomming and ontging rest services calls like you have for knx GROUP adresses with custom scripts behind the services (see weinzierl baos interface)
Is any of the above two options already possible/easy to add?
Adding it through scripts maybe feasible, but seems quite cumbersome
Threads: 46
Do you have full specification of where the inverter data is stored (handle id / uuid) and what is the data type? Our BLE mapper has profiles so end users don't have to write any code, but each profile is basically a script because there's no unified way of storing data in BLE, so each device from each manufacturer requires different approach.
As for remote services you can always add an event script and use standard remote services. It is also possible to use Lua scripts that are accessible through the web server, but we are still preparing full documentation and examples for that.
Threads: 13
Thanks for your reply
I was planning to use the following open source project for the interfacing
https://github.com/ez2X8pk61DHkdztgFT6O/...th-reader2
It seems just like a plain serial protocol
The packet layout can be found here
http://blog.jamesball.co.uk/2013/02/sma-...ormat.html
As for the Remote services, i Will have to dig more into the capabilities of lua.
I hope that you can add something for this in the future like a generic rest interface behind which we could at scripts for example
-Mylogicmachine:80/api/universalInput/1?value=on (http put)
-Mylogicmachine:80/api/universalOutput/1 (http get)
behind the call custom scripts like you have for the universal input/outputs
Threads: 13
Hello
I managed to integrate zwave, rf devices, .... by using domoticz as gateway, for now I only use it for switching zwave and rf devices and it works pretty well
domoticz you find here (I installed it on a synology nas):
https://www.domoticz.com/
below my user library
DOMOTICZ_IP = '192.168.0.12'
DOMOTICZ_PORT = '8084'
DOMOTICZ_ID_BASEMENT_COMPRESSOR = '23'
DOMOTICZ_ID_LIVINGROOM_READING_LIGHT = '215'
DOMOTICZ_ID_LIVINGROOM_VENTILATOR = '102'
KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF = '8/0/0'
KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF_STATUS = '8/0/1'
KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF = '8/1/0'
KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF_STATUS = '8/1/1'
KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF = '8/1/2'
KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS = '8/1/3'
-- write value to knx only if value changed
function writeKNX(group, value, default, typ)
local key,time
-- time = os.microtime()
-- log('writeKNX(group, value, typ)',group,value,typ)
key = 'KNX_GRP_' .. string.gsub(group, "/", "_")
-- log('writeKNX(group, value, typ)',key)
if ((storage.get(key, default)) ~= value) then
-- log('now writing writeKNX(group, value, typ)',key, group, value)
storage.set(key, value)
grp.write(group, value, typ)
-- toggle on / off
function domoticzSwitch(host, port, domoticzId, value)
local time
-- log('domoticzSwitch(host, port, domoticzId, value)',host, port, domoticzId, value)
if (value == true) then
domoticzCmd(host, port, domoticzId, 'switchlight', 'On')
domoticzCmd(host, port, domoticzId, 'switchlight', 'Off')
-- time = os.microtime() - time
-- log('domoticzSwitch(host, port)',host, port, domoticzId, value, time)
-- get On Off Status
function domoticzGetSwitchStatus(host, port, domoticzId)
local time, status
-- log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId)
status = domoticzStatus(host,port,domoticzId)
result = (status.result[1].Status == "On")
-- log('domoticzGetSwitchStatus(host, port, domoticzId)',host, port, domoticzId, result, time)
return result
-- send command to domoticz
function domoticzCmd(host, port, domoticzId, domoticzCmd, cmdParam)
local http, request,r, c, h
-- log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam)
-- load the http module
local http = require("socket.http")
request = "http://" .. host .. ":" .. port .. "/json.htm?type=command¶m=" .. domoticzCmd .. "&idx=" .. domoticzId .. "&switchcmd=" .. cmdParam
-- log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, request)
-- connect to server
r, c, h = http.request (request)
-- log('domoticzCmd', host, port, domoticzId, domoticzCmd, cmdParam, r, c, h, time)
-- retrieve a status from domoticz
function domoticzStatus(host, port, domoticzId)
-- log('domoticzStatus', host, port, domoticzId)
-- build the http request
request = "http://" .. host .. ":" .. port .. "/json.htm?type=devices&rid=" .. domoticzId--
-- log('domoticzStatus', host, port, domoticzId, request)
-- execute the http request
-- log('domoticzStatus', host, port, domoticzId, r, c, h, time)
-- decode the json object
local json = require("json")
local statusobject = json.pdecode(r)
return statusobject
here a trigger to switch a device based a knx event
SCRIPT = 'user.library'
lib = require(SCRIPT)
if not lib then alert('Event ' .. event .. ' not handled: script ' .. SCRIPT .. ' missing') os.sleep(60) return end
-- object mapped to this event must have its data type set
value = event.getvalue()
-- toggle on/off
domoticzSwitch(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR, value)
-- only write on changed data
writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF_STATUS, value, false, dt.bool)
finally my deamon script to ensure that the knx status is correctly set even if I use domoticz or my zwave remote
-- determine the domticz status
-- basement
bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_BASEMENT_COMPRESSOR)
writeKNX(KNX_GROUP_LIVINGROOM_COMPRESSOR_ON_OFF, bStatus, false, dt.bool)
-- livingroom
-- reading light
bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_READING_LIGHT)
--writeKNX(KNX_GROUP_LIVINGROOM_READING_LIGHT_ON_OFF, bStatus, false, dt.bool)
-- ventilator
bStatus = domoticzGetSwitchStatus(DOMOTICZ_IP, DOMOTICZ_PORT, DOMOTICZ_ID_LIVINGROOM_VENTILATOR)
--writeKNX(KNX_GROUP_LIVINGROOM_VENTILATOR_ON_OFF, value, false, dt.bool)
I am sure code could be cleaner but I am still learning lua
Enjoy
Next step let a mobotix cam trigger the opening/closing of doors, but manage the opening hours per user through logic machine
Threads: 46
This line will do nothing because if
require fails it produces an error and script execution stops.
Threads: 13
(26.11.2015, 07:02) admin Wrote: This line will do nothing because if require fails it produces an error and script execution stops.
ok thanks
Threads: 100
(11.11.2015, 07:07) admin Wrote: Probably by the end of the year. Which Bluetooth devices are you planning to connect?
And? can we get this as a christmas present?
Threads: 100
Is there already more information? when can we expect it and use this nice feature?
Threads: 13
Hello
Any info regarding the new firmware?
When can we expect it?
Nicky
Threads: 99
it is planned for FEB 2016.
Sorry for delay.
Threads: 100
(19.01.2016, 09:00) edgars Wrote: it is planned for FEB 2016.
Sorry for delay.
is the new firmware planned for feb 2016 or the zwave support, or both
Threads: 99
ZWave is planned to come on FEB.
New firmware (at least beta version) is planned for JAN
Threads: 13
Thanks for the update
As you notice we look forward to it :-)
Threads: 99
Some screenshots while waiting for the final release of ZWave app for LogicMachine
Threads: 100
(29.01.2016, 11:49) edgars Wrote: Some screenshots while waiting for the final release of ZWave app for LogicMachine
i can't wait
