I was wondering if you could help me.
I would like to be able to have Sonos play a specific track from my \"favorites\" with a certain KNX telegram and a specific file from my NAS drive with another KNX telegram.
Is it possible to help me out here?
Normally you create a floor and a room in the Touch Visu (not sure Mosaic works the same, but i think it does), then open the Sonos App, click on the Plus Sign on the player button, a popup should come asking for floor and room, then save and the player should be added to your visu automatically..
29.11.2017, 12:45 (This post was last modified: 29.11.2017, 12:47 by unaxboy.)
(29.11.2017, 11:46)Erwin van der Zwart Wrote: Hi,
Thank you! It works with Mosaic and super easy to do) Maybe you need to put that info in wiki.
The only thing that is happening is that the current track and play + volume state is stored, the audiofile is loaded and played, and after playingtime is passed the current track is loaded again and play state + volume gets restored as before say command. There is no grouping as those are already known in the system
In my original version it was pretty fast but latest versions are done by our development and not myself.
I have asked them to check this out.
Hi Erwin,
I am still struggling with uberslow response time when entering the following command: http://10.0.1.51/apps/data/sonos/sonos.l...uration=20
From entering the command in a web browser and until the mp3 file is played it takes 15 seconds....
Did you get anything back from the development team on this?
You mentioned a luascript that maybe could speed up the command...?
Mr.D
19.03.2018, 18:06 (This post was last modified: 23.03.2018, 01:56 by balatis.)
hello .
i use this script http://openrb.com/sonos-control-from-logic-machine/ for control sonos .
i have some questions...
1) i must to creat an address 1 byte for control or ascii?
2) how is possibole to control 2or more sonos player ?
3) how isi possibole to start play my favorite ply list from spotify ?
is possibole to upload an example on the http://4n.lv:7999/apps/?
thank you in advance.
Hi All
I just got information that Sonos is planning to block current API and allow only very basic control of the players via external systems. I don't think that you can block sonos firmware update but if yes then do it as your integration might stop working in some time. I don't know any date but this information is confirmed.
Sonos app will be updated but all the extra stuff with selecting music source, or managing playlist will be blocked. I don't think that we will be able to read current playlist or anything like that, just simple play/stop/next etc.
Apparently Sonos want to unify user experience and this is the reason behind.
(28.03.2018, 12:15)Daniel. Wrote: Hi All
This is for existing or future sonos devices or both ?
Not possible from USB, Sonos needs to have access to the file so they must be hosted by the webserver. You can put the file(s) in the Apps user folder and used them from there.
