CSS for user editing text zone
Hi all,
would someone have an example of CSS to perosnnalize the graphic aspect of a text modification field (I know how to do it for the text in display, but not in input).
Do you also know if there is a document on all editable CSS classes ?
Thank you in advance for your answers.
Dominique.
[Image: LM-forum01.jpg]
[Image: LM-forum02.jpg]
There is no documentation for CSS, you can lookup the used CSS with the browser inspector (F12).
The CSS code you are searching for is:
input.input-large {   color: #260afb;   font-size: large; }
You can also use the theme css that holds most items as a base for modify the CSS, you can find it here: http://192.168.0.10/scada/vis/theme.css.gz
Tip: Read this to learn all about css: https://www.w3schools.com/css/
Hi Erwin,
thank's for your answer, it run well.
I have now to understand the inspector mecanism to reach all the CSS objects interesting me.
Have a good week end,
Dominique
