Threads: 28
(06.11.2017, 09:29)Maris Wrote: (06.11.2017, 08:23)Daniel. Wrote: (06.11.2017, 07:48)Maris Wrote: Hi,
In iOS11 I can't open LogicMachine app. When I try to open then I see only startup screen. After that app closes.
Strange it works normally on iOS 11 and 10. Which version exactly do you have?
PS. There is v 1.0.1 available on the store.
I have iPhone 6, iOS 11.1, LogicMachine 1.0.1.
Ok I have iPhone 6 too but I kept old iOS on it to be able to test. Will update and check.
Threads: 0
06.11.2017, 10:00
(This post was last modified: 06.11.2017, 10:03 by Maris.)
OK, I found issue.
On my iPhone under Settings-> General -> Language&Region -> Preferred language order I have order:
1. Latvian
2. English
3. Russian
Then this app is crashing. In iPhone log there is error:
Logic Machine(Speech)[266] <Notice>: Cannot make recognizer for lv-LV. Supported locale identifiers are {(
"nl-NL",
"es-MX",
"zh-TW",
"fr-FR",
"it-IT",
"vi-VN",
"fr-CH",
If I put Russian as 1. then App is working.
Also works if English is 1.
Seems some bug with Language settings in App.
Threads: 28
(06.11.2017, 10:00)Maris Wrote: (06.11.2017, 09:29)Maris Wrote: (06.11.2017, 08:23)Daniel. Wrote: (06.11.2017, 07:48)Maris Wrote: Hi,
OK, I found issue.
1. Latvian
2. English
3. Russian
"nl-NL",
"es-MX",
"zh-TW",
"fr-FR",
"it-IT",
"vi-VN",
"fr-CH",
Seems some bug with Language settings in App. OK thanks for tracking it down. We will look on it.
Threads: 36
It will be nice to add custom widget with Siri comand button (like Shazam app has), and/or add some common words (basement, home, office etc.) to Siri Vocabulary to control home using "Hey, Siri".
Threads: 2
Hello Daniel.,
would it bee possible to add the following options to the iOS App (and Android App):
- Option to disable the error Message "Could not connect to Logic Machine."
I tried the iOS App with local W-Lan without internet access and I always get the error message on the screenshot.
- Option to disable the bottom bar (see screenshot)
If I only have one LM, I don't like to see and don't need this bar.
- Option to set a default LM, wich will be loaded at startup of the iOS App.
Best regards
forsterm
Threads: 28
(28.12.2017, 08:08)forsterm Wrote: Hello Daniel.,
1. Yes this shouldn't be visible when voice is disabled. Added to improvement.
2. This is part of browser and we can't really do anything about it.
3. We plan to add default selection of app for each LM. If you want app which directly will navigate to LM then Add to home screen option in safari might be better option.
If we implement what you ask then remote functionality will be gone. In the future there will be more and more possible via this.
Thanks for feedback.
Threads: 40
Is the Spanish language available for voice command in IOs App?
Threads: 28
(09.01.2018, 13:21)Carlos Padilla Wrote: Hi,
It is available on Android now. We are going to update iOS app soon and will add Spanish.
Threads: 40
(09.01.2018, 13:28)Daniel. Wrote: (09.01.2018, 13:21)Carlos Padilla Wrote: Hi,
Thanks Daniel, approximately when it would be updating?
Threads: 28
(10.01.2018, 17:31)Carlos Padilla Wrote: (09.01.2018, 13:28)Daniel. Wrote: (09.01.2018, 13:21)Carlos Padilla Wrote: Hi,
Around a week. I want to implement several other improvements at the same time which were mentioned here earlier.
Threads: 28
V 1.0.2 is available in the store
Chang log:
- New languages added
- Scan is switched off when devices is on mobile data
- Popup 'Logic Machine connected' is only shown when Siri voice is enabled.
- Scan can be switched off via scan button.
Threads: 0
(16.01.2018, 09:34)Daniel. Wrote: Hi
Chang log:
App still crashing if first language is Latvian :-(
Threads: 28
(16.01.2018, 10:16)Maris Wrote: (16.01.2018, 09:34)Daniel. Wrote: Hi
Chang log:
App still crashing if first language is Latvian :-( Ehh forgot about that one, sorry  on top of my list now.
Threads: 21
Hello !
Very good with french language
thank Daniel
Jean-Marc
Threads: 41
Do we first have to delete the old version and re-install?
I can see that there is a new version in the App store, but I have not yet received an update notification.
Threads: 28
(22.01.2018, 22:43)baggins Wrote: Do we first have to delete the old version and re-install?
Can you send screenshot of what you see? You should just install it.
Threads: 41
(23.01.2018, 10:06)Daniel. Wrote: (22.01.2018, 22:43)baggins Wrote: Do we first have to delete the old version and re-install?
This is what I see in the Apple App store:
This is what I see on my iPad when I click on "Open":
Threads: 28
Hm.. what version of iOS do you have ?
you could try one of those tips https://www.lifewire.com/iphone-cant-upd...ix-4057706
Threads: 41
(23.01.2018, 10:33)Daniel. Wrote: Hm.. what version of iOS do you have ?
On the iPad: 10.2.1
On iPhone: 10.1.1
Threads: 28
I just installed it on my ipad and iphone but I always have beta versions which are treated as separate app and the one from store is like new one again. Does anybody else has the same?
Most likely uninstall and install will solve it but I wonder why it is like that. I have latest iOS too.
