would it bee possible, to create the ability, that I can take the Android App (and iOS App) in the foreground by lua script for example?
By the way, can I send push notifications from spacelynk / homelynk? Where do I find the needed lua library?
I think the only way is via sending push notification and then when user click on it app will open.
For HL/SL you need cloud app but it is not supported by SE at the moment.
Is it possible to install cloud app over "Install from file" function on spacelynk / homelynk?
Or if I look at Script 1 (https://forum.logicmachine.net/showthrea...19#pid6419) I think I would only need the "pusher.lua" file, correct?
No it is not just this. You have to be logged in to our cloud via the app. We are not allowed to share apps to SE customers without prior authorization from them.
sorry
(09.02.2018, 17:59)Daniel. Wrote: No it is not just this. You have to be logged in to our cloud via the app. We are not allowed to share apps to SE customers without prior authorization from them.
sorry
Do I have to logged in to your cloud, too, if I want to use the push notifications only over my local lan?
For now only for homeLYnk (HW1) and Wiser for KNX (HW2), spaceLYnk is positioned for buildings where a app like this is mostly not required. Apps in buildings are normally done with Adapti Apps.
We released new version of Android app to the Play Store. What is new:
- new more clean design.
- For each device we can select default view.
- We can select which device to open automatically when opening the app. This will allow us to go directly to visu by just pressing the app icon.
- Voice commands are logged in app for easy debugging. This is only stored in the app.
11.03.2019, 09:51 (This post was last modified: 11.03.2019, 10:12 by buuuudzik.)
When do you plan releasing iOS version?
How can I select the default LM and run it when app starts? I have 3 LMs in app and checked "Show the default device when the application starts?" and on every LM there is autoload checked but when I start app it doesn't start any default LM.
And also how can I add to my app LM which is connected to client's account in cloud for service? Where should I type controller id or name?
Yes, I've switched on this option without a result. But which device is the default one?
I know that app supports only 1 account, but permissions allows other accounts to use its devices(specific apps from these devices). How can I reach device which was allowed to be reachable from my account?
(11.03.2019, 11:59)buuuudzik Wrote: "You need to set one of the device to be default. There is option Auto-load device. Only one should be set this is in LM settings."
I've tested it. Only 1 device has autoload on but it is not working (it not runs the default lm when app starts).
"When you are in the cloud and you are in Mosaic you can switch view to another LM in top right corner."
I see this function but both on the browser and on app I have only my devices and no allowed by other users. I am using Mosaic 3.0.
For the auto load it is a bug. It work fine on my version which I was testing before release. Seems something is different in the version on app store.
Mosaic 3.0 is not released for cloud yet so don't claim anything for it yet.
Hi Buuuudzik
Can you uninstall the app and install again. I reverted back to previous (beta) version and autoload was working fine now I installed back the version form store and it is also working. I don't see any differences in my configuration.
