Gardena smart
Anyone already linked a Gardena Smart gateway?
Here my first code to read a Sensor and write the moisturelevel and batterylevel.
function getData()   https = require 'ssl.https'   require('json')   socket.http.TIMEOUT = 5    local cUsername = 'email@abc.com'  local cPassword = 'password'     -- get session info   local cBody = '{"sessions":{"email":"' .. cUsername .. '","password":"' .. cPassword ..'"}}'   local cReq = {}   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/sessions'   result1 = https.request({       url = cUrl,       method = 'POST',       headers = {         ['content-length'] = #cBody,         ['content-type'] = 'application/json'       },       source = ltn12.source.string(cBody),       sink = ltn12.sink.table(cReq)   })   if result1 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       token = cReq.sessions.token       user_id = cReq.sessions.user_id     end   end   -- get location info   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/locations/?user_id=' .. user_id   result2 = https.request({       url = cUrl,       method = 'GET',       headers = {         ['content-type'] = 'application/json',         ['X-Session'] = token       },       sink = ltn12.sink.table(cReq)   })   if result2 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       local loc_name = cReq.locations[1].name       loc_id = cReq.locations[1].id     end   end   -- get device info   local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/devices?locationId=' .. loc_id   result3 = https.request({       url = cUrl,       method = 'GET',       headers = {         ['content-type'] = 'application/json',         ['X-Session'] = token       },       sink = ltn12.sink.table(cReq)   })   if result3 then     --log(cReq)     cReq = table.concat(cReq)     cReq = json.pdecode(cReq)     if cReq then       --log(cReq)       local dName = cReq.devices[1].name       for k,v in pairs(cReq.devices) do         --log(v)         --log("Found the following GARDENA "..v.category)         --log("Name: "..v.name)          --log("Identifier: "..v.id)         -- gateway         if (v.category == "gateway") then          -- sensor         elseif (v.category == "sensor") then           for a, b in pairs(v.abilities) do             for c, d in pairs(b.properties) do               --log(d.name)               --log(d.value)               if (d.name == 'last_time_online') then                 --check = tostring(d.value)               elseif (d.name == 'humidity') then                 grp.write('1/1/1', tonumber(d.value))               elseif (d.name == 'level') then                  grp.write('1/1/2', tonumber(d.value))               end             end           end         -- onbekend apparaat         else           log('onbekend gardena apparaat: '..v.category)         end       end     end   end end
You need to check the result of https.request call instead of cReq variable. Since it's defined as a table first if cReq then... will evaluate as true.
(25.04.2018, 06:45)admin Wrote: You need to check the result of https.request call instead of cReq variable. Since it's defined as a table first if cReq then... will evaluate as true.
thanks for the comment.
gjniewenhuijse,
I'm interested in this project as i'm installing a Smart Sileno Life 750 robotic mower this week and planning to extend this with Smart Water Control + Sensor and Smart Pressure Pump and maybe some Smart Power Plugs to control lights.
I'm a novice on scripting and things and would like to learn and understand more of this. It's not always clear where things go and steps to follow to get things working.
Can you, or anyone, explain me what to do and where to do it? I have a HL, wich is similar to the LM.
Thx in advance
I found this page with API for all Gardena Smart products:
https://developer.husqvarnagroup.cloud/a...I#/general
Kind regards,
Novice DIY with a HL and KNX basics trying to ...
"This API has moved to the official developer portal. Please follow the instructions at https://developer.husqvarnagroup.cloud"
