Dear all,
I am workin on a project on which LM will be communicate with 4 modbus devices in TCP/IP.
Every devices will have about 300 modbus variables.
Obviously I will import variables with Json file. Considering the big amount of variables is there the opportunity to link the modbus variable to KNX address in automatic and not manually step by step?
Because if I do a mistake with json file then I have to link modbus variables to knx group address again.
PS: Make backup before you run it because there is a lot created (:
It creates 255 objects each run and skips already mapped objects, so you need to change to address scope and run it again for the next 255 objects. So for 1200 objects you need to run it 5 times.
I use spacelynk like a modbus slave (The master is a Scada). I will comunicate DI, AI, DO, AO with the Scada.
It's possible use modbus json profile to implement it?
Otherwise can I create a list with all the objects (modbus-KNX) and a script to implement it?
Thank you in advance.
(02.04.2019, 06:20)fabiorusco Wrote: Hello,
Profiles are only for master, there is no other way. This script is very ease, you just have to fill the array for object mapping and corresponding dpts in second array.
I sent you already full example above. You need to fill these arrays
-- list of coil mapping, starting from 0coils = { '1/1/1', '1/1/2' }
-- list of register mapping, starting from 0registers = { '2/2/2', '3/3/3' }
-- list of register data types, element count must match registers tableregdt = { dt.int8, dt.uint16 }
Coils are binary objects and there you just add group addresses.
Registers are numeric objects and there you also have to add group addresses.
For registers you also have to add register dpt in regdt table. In this example group 2/2/2 is dt.int8, and group 3/3/3 is dt.uint16. For each register you need to add dpt in next table in the same order.
Hope this is clear.
The memory map that you have uses registers as bit masks. If this can be changed I suggest using coils instead which are meant for storing Boolean variables. This will make mapping to objects much easier.
Here is modified slave script. I doubled the arrays for registers and added a shift. Fill accordingly all the arrays. registers1 will start from 4096 and registers2 will start from 8192. Make sure you add corresponding regdt for each register. Shift can be changes by shiftR1 or shiftR2 parameter.
